Rough noises/rumbling when load changes
suther
Post18-06-2004, 21:37    Subject: Rough noises/rumbling when load changes Quote
Hello everyone,
Drive a SEAT Alhambra TDI 115hp with a 6-speed manual transmission, model year 2004.
If I am in the 2nd or 3rd By playing with the gas and easily switching between push and pull operation, I can create a rather loud noise that sounds like grinding gears.
The same noise occurs briefly when I accelerate quickly with a lot of gas, make a quick gear change, and the tachometer drops from around 2500 rpm to 1300 rpm when I engage the clutch.
Error memory is empty.
I initially suspected a pan, lid, or something similar, but everything feels solid.
My idea is that the shift cable, or the shift shaft, is what makes the 'clunking' sound when it's being 'manually' engaged.
Maybe one of you has a brilliant idea before I start looking in the wrong direction.
Thank you.
Suther
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 PD-TDI ATD engine: hard shifting/jerking under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking noise during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C Variant, 1.4 TSI - Noises during load changes Transmission, Chassis, Body & Interior
No new posts Transmission damage? Sagging under load Transmission, Chassis, Body & Interior
No new posts Popping noises during load changes on a VW Golf A48E 1.9 TDI Diesel Engine Technology
No new posts Jerks during load change Diesel Engine Technology
