Timing Belt Replacement: No Diagnostic Tool Needed?
brocky
Post18-06-2004, 7:05    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
On my Audi A4, 110 horsepower, manufactured in December 1997, the odometer reads 180,000 km.
A timing belt replacement.
The last time I did something like this myself was...
On my Golf 1, with a 55 horsepower, 1.6-liter engine.
Back then, you had to use a special measuring device to re-measure the...
Check and, if necessary, correct the injection timing.
Now I've read the report in 'Auto Service Praxis' that...
Now, this is usually done with a diagnostic device.
1) Do you think that is necessary?
2) Yes, I saw that there's software available here.
and what can you do with an adapter?
3) What kind of adapter would I likely need for my car?
Brocky.
Translated on 01-10-2026, 22:30.
Gremlin
Post18-06-2004, 7:52    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
-> technical articles -> troubleshooting & guides > checking and adjusting the 1.9 TDI rotary injection pump.
-> technical articles -> troubleshooting & guides > timing belt replacement guide
1: Yes.
2: Yes.
3: One of the offered devices, or a functionally equivalent one (opto-couplers or minimal interfaces may not necessarily work on every computer).
CU Gremlin.
Translated on 01-10-2026, 22:32.
joergs
Post18-06-2004, 7:56    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
It can also be done with a dial indicator, but please read the 'Hähnlein MegaMonster cold start thread' to understand the potential risks involved.
Conclusion: While the basic setting with a dial indicator is limited, it can be dynamically adjusted after checking.
Translated on 01-10-2026, 22:33.
brocky
Post18-06-2004, 8:04    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Thank you for the quick response.
So, is this part enough?
a)
http://shop.dieselschrauber.de/product_info.php/products_id/36
or does it have to be something like that:
b)
http://shop.dieselschrauber.de/product_info.php/products_id/41
or even not at all.
c)
http://shop.dieselschrauber.de/product_info.php/products_id/45
The price is somewhere between 100 and 300 euros.
What are the minimum requirements, or what would you recommend?
If it's supposed to be a 300 Euro part, I'd rather go to a workshop.
'Over there, the cost of changing it at a VW/Audi service center is 320 euros.'
Translated on 01-10-2026, 22:34.
Gremlin
Post18-06-2004, 8:17    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
The adapter doesn't really matter. You can choose between COM or USB depending on your preferences and available options.
However, you need a full version of VAG-COM.
or someone you know who already has the adapter and software, or who works at VAG and can lend it to you for the 1551 diagnostic procedure...
CU Gremlin.
Translated on 01-10-2026, 22:35.
brocky
Post18-06-2004, 8:22    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Okay, I'll get the full version of VAG-COM.
add and then possibly...
Please provide me with this adapter.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=30921&item=7905824236&rd=1
or should one generally avoid using such eBay adapters?
Michael.
Translated on 01-10-2026, 22:36.
joergs
Post18-06-2004, 9:46    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Okay, if you're asking me, as someone who uses adapters, I would advise against buying from eBay. If you happen to have problems with the adapter from here, you'll get support. With eBay products, they probably won't be able to support you. The support offered by sellers there is also terrible because they're only focused on selling. Also, on eBay, you'll almost exclusively find those optocoupler interfaces that are known to cause problems.
Translated on 01-10-2026, 22:37.
Gremlin
Post18-06-2004, 9:58    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Furthermore, on eBay, you almost exclusively find optocoupler interfaces that are prone to causing problems.
Yep, I actually have one of those here right now, for modification purposes.
opto-adapter according to Jeff's interface. The optos were rendered unrecognizable using a Dremel.
It's unnecessary to mention that the adapter, despite its etched circuit board and actually nice design, is junk. It constantly loses connection.
If I look at my hastily assembled setup... it ran for 6 hours straight without any interruptions icon_wink.gif.
icon_arrow.gif from eBay only with a 100% guarantee regarding the type of adapter and corresponding options for making claims...
A small piece of wisdom from India: A cheap thing is not a good thing. A good thing is not a cheap thing.
CU Gremlin.
Translated on 01-10-2026, 22:38.
brocky
Post18-06-2004, 10:31    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Thank you for the feedback.
Well, actually, the guy in the eBay ad is even advertising the fact that he doesn't use optocouplers, but a MAX232 instead.
Do you think he's lying?
Translated on 01-10-2026, 22:40.
joergs
Post18-06-2004, 10:45    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Hmmm...
'Trying is better than just reading about it. But: I once ordered tachofolies from this guy. It also said: 'No cheap printing on your home PC and no ink splatters.' First, it took 5 weeks because there was no template available for a DZM (a type of engine) with 5500 RPM, which is common for TDI engines. Then, when the stuff finally arrived, after a lot of threats, it was the worst quality imaginable...'
Decide for yourself! It's also strange that he has a new name again...
brocky
Post18-06-2004, 10:50    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Hmm,
Okay, I guess I should probably order here after all.
Possibly the kit.
'Hey, do you think the €65 price is justified for the kit?'
Are the installed components that expensive? A small profit margin, up to about 10%, is okay, but anything more is not.
Michael.
Translated on 01-10-2026, 22:42.
PrivatBereich
Post18-06-2004, 13:35    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
Are the 65 euros justified for the kit?
Are the installed parts that expensive?
Mit einer geätzten Platine und dem ODB-Stecker ist der Preis völlig in Ordnung. Alleine den Stecker wirst du kaum unter 15Euro bekommen, obwohls 'nur' ein Stück Plastik mit Kontakten ist. AbHe's just rare.
Private.
WarLord
Post19-06-2004, 13:10    Subject: Timing Belt Replacement: No Diagnostic Tool Needed? Quote
'Do you think the €65 price for the kit is justified?'
The price is definitely justified. It includes everything you need (OBD connector, shareware version of VAGCom on CD with a nice menu, and a €10 voucher if you decide to purchase the full version of VAGCom). I also have the adapter, and it works perfectly.
Best regards, WarLord.
Translated on 01-10-2026, 22:43.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Car Battery Without Losing Data Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 4: Replace Strut Mount Without Spring Removal Transmission, Chassis, Body & Interior
No new posts Replacing front wheel bearings without removing the struts Transmission, Chassis, Body & Interior
No new posts Diagnosis of control unit without a vehicle On-Board Diagnostics (OBD)
