AJM Injector Pump GRA Calibration
joggigery
Post04-08-2002, 7:52    Subject: AJM Injector Pump GRA Calibration Quote
Hallo habe den GRA-Nachrüstsatz-Et.Nr.110998527 bei meinen PD probiert eingebaut,aber er funktioniert nicht, jetzt habe ich mich bei VW erkundigt die sagen er ist nicht für PD ,was ist bei dem anders .Gibt es eine möglichkeit in zu benutzen ,anderen Schaltplan oder so.....wäre dringend den ich habe das Auto noch zerlegt. Danke icon_sad.gif
This is the retrofit kit for all Golf IV TDI engines (engine codes AGR, AHF, ALN), but not PD engines. It includes the turn signal lever, wiring harness, and installation instructions. I used the 4 wires on the engine connector (the black 10-pin connector) at pins 1, 2, 3, and 9, and connected a wire with a 5-amp fuse as described. I also activated the engine control unit (11463), and the green light on the tachometer is lit, but it's not working.
That's why I believe the injectors should be connected differently, but I'm not sure how. I have a Golf IV TDI PD with an 85 kW engine, engine code AJM, manufactured in 2001.
I hope for help. Thank you.
Translated on 27-09-2026, 14:23.
D.
Post04-08-2002, 12:52    Subject: AJM Injector Pump GRA Calibration Quote
Hi!
While I'm not a mechanic myself, you might want to check out the latest issue of 'Gute Fahrt' magazine; it describes how to retrofit the GRA (presumably a specific automotive feature) for PD (likely another specific automotive feature).
Best regards, D.
Translated on 27-09-2026, 14:25.
joggigery
Post06-08-2002, 17:08    Subject: AJM Injector Pump GRA Calibration Quote
There's nothing listed for PD.
joggigery
Post06-08-2002, 17:09    Subject: AJM Injector Pump GRA Calibration Quote
Hello, where are the experts? Does anyone have any advice? How can I use VAG-Com to check if the GRA (Gas Recirculation) is actually activated? (The light is on.)
greetings
Michael748
Post06-08-2002, 22:13    Subject: AJM Injector Pump GRA Calibration Quote
In issue 8/02, it's listed for PD.
Translated on 27-09-2026, 14:26.
Tortsch
Post07-08-2002, 6:38    Subject: AJM Injector Pump GRA Calibration Quote
'While wv himself says it's not possible for PD, it actually is, but the option needs to be enabled.'
joggigery
Post10-08-2002, 13:48    Subject: AJM Injector Pump GRA Calibration Quote
I would like to thank Rainer; the GRA is now working.
realsurfers
Post18-06-2004, 20:05    Subject: AJM Injector Pump GRA Calibration Quote
Hi! While your connection problem with the AJM motor happened a while ago, I'm now facing the same issue with my A4: I have the GRA (presumably a control unit), but I'm unsure how to connect the cables. I would appreciate any help, especially a step-by-step guide on how to connect everything!
Translated on 27-09-2026, 14:27.
gerbi
Post20-06-2004, 2:33    Subject: AJM Injector Pump GRA Calibration Quote
I would like to thank Rainer; now the GRA is working.
What was the problem?
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pump-nozzle Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
No new posts TDI Golf 4: Convert to Pump Duse System Diesel Engine Technology
No new posts Golf 4 Performance Issues: 110 HP Pump Denoise Diesel Engine Technology
