Opel 2.2 DTI: Cheap Parts? (Pre-2002)
m3nx
Post24-06-2004, 18:55    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
Hello!
Is it possible to achieve similar performance gains with a 2.2 DTI engine (like in the Zafira, manufactured in 2001) through '10-cent tuning' methods?
Supposedly, the Vp44 doesn't work well, but you can find tons of 'power boxes' for Opels on eBay, mostly for €15-20, so there must be something to it. It definitely won't cost me more than €5 to build one myself.
Thank you for any tip; I don't want to order one of those things for €20, take it apart, and then find out that it only contains a resistor again icon_smile.gif.
Translated on 08-08-2026, 5:36.
Post25-06-2004, 15:32    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
That's probably just the usual diesel temperature manipulation you see in production cars.
It usually consists of a casing, a lot of glue, and ONE resistor.
This has probably already been discussed and analyzed in this forum, but I'm too lazy to search for it myself.
Translated on 08-08-2026, 5:37.
m3nx
Post25-06-2004, 16:33    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
Hi!
Okay, that's clear for VAG cars, but I wasn't sure if it would be as straightforward with Opel. I don't even know exactly where the temperature sensor is located.
However, hold on a minute... As far as I know, this isn't a CDTI but just a DTI, which is a turbocharged diesel. Is there anything known about that?
Translated on 08-08-2026, 5:38.
Post25-06-2004, 16:59    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
CDTI is also a common rail system, so it definitely doesn't use a VP44 pump.
The DTI must have the VP44.
Translated on 08-08-2026, 5:39.
m3nx
Post26-06-2004, 11:20    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
Yep, and it seems like nobody has ever worked on the VP44 before, or no one wants to reveal anything about it icon_sad.gif.
WarLord
Post26-06-2004, 14:09    Subject: Opel 2.2 DTI: Cheap Parts? (Pre-2002) Quote
Hmm, what does the control unit do in the VP44? Because it has its own control unit.
Best regards, WarLord.
Translated on 08-08-2026, 5:40.
No new posts versuche mit 10cent Diesel Engine Technology
No new posts 10cent tuning? Diesel Engine Technology
No new posts Questions about 10cent Tuning {QUESTION_1} {QUESTION_2}... Diesel Engine Technology
No new posts 10cent mit alter VP34? Diesel Engine Technology
