Thank you for the tip, I've now set it to 111, which is the maximum. It's now working great
'It produces some black smoke when driven at full throttle, especially if you really push it. However, during normal driving, you don't notice anything. You can't see any black smoke from inside the car. Is this normal, or should I be concerned? The car is rarely driven aggressively; most of the time, it's driven slowly and carefully. So, it's not that bad if it produces a little black smoke at full load, right? Could the injection time become so long that it melts the pistons or causes other damage, or is the system designed to prevent that from happening?'
