Brösel Guest
28-06-2004, 9:38 Subject: Steering Wheel Noise: Causes & Solutions |
'When I turn it, I hear a grinding noise. Has anyone else experienced this?'
Translated on 28-09-2026, 9:34.
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
28-06-2004, 11:28 Subject: Steering Wheel Noise: Causes & Solutions |
Hello Brösel!
I'm simply guessing that the problem is caused by the rotation of the steering column shaft being obstructed by the motor splash shield.
Try the following while the vehicle is stationary: When you turn the steering wheel slightly, listen for any grinding or squeaking noises.
If so, then a simple lubrication application to the rotating joint (radial seal between the steering column and the engine block) will suffice.
The noise you're hearing likely occurred while driving because the steering system tends to slightly oscillate when turning, especially during initial steering input.
This noise only occurred for me when the weather was quite warm.
Good luck with your investigation!
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 28-09-2026, 9:35.
28-06-2004, 17:23 Subject: Steering Wheel Noise: Causes & Solutions |
Alternatively, it could be the contact point of the horn, or the roll/coil/or-whatever-it's-called cable that transmits signals for the airbag, although in that case, it would likely occur in other driving situations as well.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 28-09-2026, 9:37.
WarLord Guest
28-06-2004, 21:13 Subject: Steering Wheel Noise: Causes & Solutions |
Roll/Wickel-or-whatever-you-call-it cable transmission of the airbag.
The part is called a slip ring.
Best regards, WarLord.
28-06-2004, 21:41 Subject: Steering Wheel Noise: Causes & Solutions |
Are you sure?
Because, in my opinion, there's no grinding involved there; that's actually the trick of this winding mechanism – unlike the sliding contact used for the horn.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 28-09-2026, 9:38.
