LDA Hose/Schlauchdurchführung in G3 -> Frustration
misterx
Post27-06-2004, 15:52    Subject: LDA Hose/Schlauchdurchführung in G3 -> Frustration Quote
Hi everyone!
I finally bought an LDA, and I also know where it needs to be connected, but I have no idea where I can run the hose into the interior. How much do I need to disassemble my car?
Does anyone have a tip?
Thank you in advance,
Mr. X
x world one
Post27-06-2004, 21:46    Subject: LDA Hose/Schlauchdurchführung in G3 -> Frustration Quote
I connected my LDA (Low-Pressure Air) hose to the air intake hose that leads to the control unit. I cut this hose approximately 10cm before it enters the water reservoir and connected the LDA hose using a T-piece. I then attached the LDA hose to the cable duct inside the water reservoir. It was a bit fiddly to get this in place, but it works. Then, I removed one of the many free rubber plugs in the wall behind the coolant expansion tank. I fed the LDA hose through the hole, and after some trial and error, removing a good "plug", I ended up coming out directly just above the fuse box in the driver's footwell. I then ran the hose further along inside, under the trim.
Spritmonitor
No new posts Workshops are driving me to despair: LLK is leaking Diesel Engine Technology
No new posts Drum brakes on my Polo 9N3 are driving me crazy! Transmission, Chassis, Body & Interior
