High Oil Consumption: Causes & Solutions
T4-TD Einsteiger
Post25-06-2004, 7:27    Subject: High Oil Consumption: Causes & Solutions Quote
Hello, I need your help.
I recently bought a 1993 T4 with a 1.9L TD engine, and I haven't been very happy with it so far. Initially, the car was very difficult to start and produced a lot of smoke, to the point where the fire department almost got involved. My mechanic inspected the engine and concluded that the electronic fuel injection system (ESP) was faulty. The ESP was rebuilt, but the problem reappeared after 100 km. A worn gear was found, which was causing the timing to be incorrect (the ESP may not have been broken in the first place). The van is running now, but it's consuming a lot of oil, or to put it another way, the diesel is burning with the oil. After 100 km, 2 liters of oil are used. My mechanic now believes the problem is either with the valve stem seals or the oil scraper rings.
My question: Could such high fuel consumption be caused by this? The compression is 30 bar in all four cylinders.
Translated on 02-10-2026, 21:51.
Matze22
Karma: +7 / -1   Thank you, like it!
Post25-06-2004, 7:53    Subject: High Oil Consumption: Causes & Solutions Quote
Is it possible that the turbocharger is about to fail and that oil is leaking into the combustion chamber through the turbine shaft?
Just make sure this thing doesn't become a "runaway" situation!
Greetings.
Translated on 02-10-2026, 21:53.
Julian
Post25-06-2004, 9:09    Subject: High Oil Consumption: Causes & Solutions Quote
Hmm... if the compression is that good, it's probably not the engine itself. Give your 'mechanic' a hint and suggest they check the turbocharger. I think that's the problem!
'Two liters passing through the valve stem seals would be a world record. It also can't be the wiper rings, because otherwise the compression would also be reduced or uneven.'
Translated on 02-10-2026, 21:54.
Post25-06-2004, 10:06    Subject: High Oil Consumption: Causes & Solutions Quote
... a little reading material to go with it:
T4-TD Einsteiger
Post27-06-2004, 10:10    Subject: High Oil Consumption: Causes & Solutions Quote
Thank you for the prompt information. I will pass this suggestion on to my mechanic. Thank you!
Translated on 02-10-2026, 21:55.
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T5, 2.0 BiTDI, excessive oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MKB AGP, Increased oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Tuning Extreme Diesel Engine Technology
No new posts CUPA: Frequent Regnerations - Causes & Solutions Diesel Engine Technology
No new posts Oil Consumption: Causes and Solutions Diesel Engine Technology
No new posts Oil consumption!!! Diesel Engine Technology
