Deactivate Front Passenger Airbag in AKN Car
René_S
Post27-06-2004, 12:01    Subject: Deactivate Front Passenger Airbag in AKN Car Quote
As often happens, the front passenger airbag needs to be deactivated due to the presence of a child seat. In other discussions, people have mentioned using resistor solutions, and that this is not officially supported by VAG (Volkswagen Group).
Is the end resistance sufficient, or do I need to/can I disable the airbag using VAG-Com?
Is the resistor available from VAG, even if they don't support the process?
Thank you.
René.
Translated on 27-09-2026, 23:12.
Post27-06-2004, 13:57    Subject: Deactivate Front Passenger Airbag in AKN Car Quote
Hello Rene,
For safety reasons, I would disconnect the airbag electrically from the control unit and incorporate the termination resistors mentioned into the wiring.
The end resistors are sufficient; they simulate the presence of a connected airbag to the airbag control unit.
The part numbers should be known to your dealer, as this is a common problem.
Translated on 27-09-2026, 23:13.
No new posts Deactivate front passenger airbag Diesel Engine Technology
No new posts Retrofitting the passenger airbag switch in the A4 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Disable AGR? Diesel Engine Technology
No new posts Disable T4 WFS: How to & Troubleshooting On-Board Diagnostics (OBD)
