Experiences with Serial/USB Adapters
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Holger247
Post06-07-2004, 16:26    Subject: Experiences with Serial/USB Adapters Quote
I'm planning to buy a new laptop, but unfortunately, there are very few that have a serial port. While it shouldn't be the most important factor when buying, I suspect that a built-in serial port simply works better than a USB-to-serial adapter. The background is that I already have a well-functioning (original) diagnostic adapter that uses a serial connection.
Currently, there are two notebook models available: one with a serial port and one without. The model with the serial port costs approximately 150 euros more, but has slightly better specifications.
How well does diagnostics work with a USB/serial converter? What are your experiences?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 11-07-2026, 16:28.
joergs
Post06-07-2004, 16:38    Subject: Experiences with Serial/USB Adapters Quote
Try using the search function. We've used it before quite often.
If you ask me: either a USB diagnostic adapter or a direct serial interface.
I have tested two USB to RS232 adapters and they are working fine. I can't find any disadvantages, but I suppose this cannot be generalized!
Translated on 11-07-2026, 16:30.
Karma: +807 / -0   Thank you, like it!
Post06-07-2004, 17:01    Subject: Experiences with Serial/USB Adapters Quote
Okay, I'm ready. Please provide the German text you want me to translate into English.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts OBD-2 interface does not work with USB serial adapter. Diesel Engine Technology
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts [Poll] OT: Experiences with eBay Transmission, Chassis, Body & Interior
No new posts Experiences with 150 PD and p-Box Diesel Engine Technology
