Oil Pressure Sensor: Start Problem?
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post20-05-2012, 0:19    Subject: Oil Pressure Sensor: Start Problem? Quote
I remember reading something about this here before, but I can't find it again, and I'm not entirely sure about it.
Are there any Motor Start Gauges (MSGs) or programming solutions that prevent a motor from starting until a certain value X of oil pressure is reached?
I don't want to change or modify anything; it's purely for debugging and, occasionally, out of curiosity.
Translated on 13-09-2026, 5:58.
Post21-05-2012, 11:16    Subject: Oil Pressure Sensor: Start Problem? Quote
I am not aware of any analysis of oil pressure specifically for the starting process. However, some engine control units only allow the engine to start when it reaches a certain minimum speed (and hopefully, therefore, sufficient oil pressure).
Translated on 13-09-2026, 5:59.
klahaui
Avatar-klahaui
Post21-05-2012, 23:01    Subject: Oil Pressure Sensor: Start Problem? Quote
Thank you, that's how I remembered it from here as well.
Translated on 13-09-2026, 6:00.
Post25-05-2012, 10:05    Subject: Oil Pressure Sensor: Start Problem? Quote
dieselschrauber wrote:
Some engine control units only allow warm starts above a certain minimum engine speed (and thus, hopefully, with sufficient oil pressure).
However, I find it questionable whether this fuel injection lock is actually (only) implemented in the software for oil pressure reasons?
Or are exhaust emissions playing a role again? -> The lower the starting speed of the first injection/combustion, the worse the exhaust values are likely to be until the idle speed is reached...?
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Pressure After Starting? Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts TDI AFN Vacuum Hose - MSTG Diesel Engine Technology
No new posts Passat 3B V6 TDI: MSTG Failure? On-Board Diagnostics (OBD)
