Can AFN be blocked?
Klausel
Post15-07-2004, 22:55    Subject: Can AFN be blocked? Quote
Hello!
AFN engine in a Volkswagen Golf III, manufactured in 1997.
My gas station attendant told me that he once...
He had a Golf III AFN. What bothered him was that the AFN had a slight problem when starting.
it was something he had to force himself to swallow, and this had happened to him multiple times.
My AFN, however, is not susceptible at all - quite the opposite:
Even on inclines, it's possible to start moving without using the accelerator.
He can drive up even steep inclines like that.
I just found something in the thread.
/viewtopic.php?t=5054&highlight=vollgas+%2AJurgen%2A&sid=4c8e798db59a869c12acf231cea1000
Ulf has also written about the "defense" of the idle speed.
has, where "the AFN tends to be more proactive and assertive rather than being held back."
What was broken on the Tankwart-AFN?
Or perhaps it was different in the 1997 or 1996 model year (like mine).
is it a 1998 model year)?
Greetings,
Klaus.
... who (he) learned how to adjust the VTG rod - thanks to...
Translated on 31-08-2026, 10:19.
Gremlin
Post15-07-2004, 23:31    Subject: Can AFN be blocked? Quote
I've already stalled the engine 2544 times *). Everything works fine if you're not used to the clutch.
CU Gremlin.
V10 biturbo - 16 liters - 440 horsepower - 2000 Nm.
Translated on 31-08-2026, 10:21.
Post16-07-2004, 10:01    Subject: Can AFN be blocked? Quote
I also want to disable trucks (but I would first have to be allowed to drive them icon_smile.gif).
Subject:
The graphic below clearly shows that the 1Z (AF STG) really puts its foot down on the accelerator when it's pushed hard.
The pink line represents the fuel injection amount - starting completely with 0% pedal - all the way up to the 5th gear icon_smile.gif}.
http://www.luxus-wg.de/~martin/auto_bilder/gas_emenge.gif
Translated on 31-08-2026, 10:22.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transmission Control Unit: Recording Issues On-Board Diagnostics (OBD)
No new posts Brake Pedal Stuck? Check Master Cylinder Now! Transmission, Chassis, Body & Interior
No new posts JMA lässt sich bei -13 Grad besser schalten ?! Diesel Engine Technology
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
