Hi everyone
I'm having a problem with my Allroad, manufactured in 2001.
The seat memory function is not working on the passenger side.
I have observed all the values using VAg-COM, and all functions are displayed correctly.
This means the seating position is displayed accurately and changes when adjusted.
"When I operate the buttons on the seat memory switch, everything displays correctly. For example, when I press the On/Off button, or when I tap the individual memory buttons from 1 to 3, 100, 010, or 001 is displayed respectively."
Alone, it doesn't make a sound.
Could it be that the ECU (Engine Control Unit) has a fault, but it's not being displayed?
I know this story isn't tragic.
But people generally prefer to have a car that works
Sure, no problem! Here's the translation:
"Thank you in advance!"
