Fuel Injectors: 239,000 km / 148,000 miles
Weini
Post01-07-2004, 18:46    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
Hello!
Today, I replaced the three fuel injectors in my 12-year-old Audi 80 TDI (1Z), and I was quite surprised when I examined the injectors. new_shocked.gif
The engine was still running perfectly and it wasn't smoking, but I can't imagine that injector nozzles that are so coked up would still produce a good spray pattern icon_surprised.gif.
Well, everyone can form their own opinion about whether it's better to replace those good things after all.
Have fun trying it out!
Regards - Weini
http://www.geocities.com/weini.geo/tdi/tdi.html
 File size:  46.91 KB
 Viewed:  4790 times
Translated on 23-10-2026, 6:59.
Julian
Post01-07-2004, 18:51    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
The link is not working...
Sorry, this site is temporarily unavailable!
Translated on 23-10-2026, 7:00.
xxl
Post01-07-2004, 19:52    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
'That's normal. When there's high traffic, Yahoo sometimes turns the page off and on. There's a maximum number of visits allowed per hour.'
Try it again later.
Best,
Alex
schnappi
Post01-07-2004, 20:08    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
When should the nozzles normally be replaced?
Translated on 23-10-2026, 7:01.
daytrader
Post01-07-2004, 20:13    Subject: Fuel Injectors at 239,000 km: Picture Quote
they will probably look like mine, which currently have 243,000 km. icon_eek.gif
joergs
Post01-07-2004, 20:28    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
Two of them look like they've dripped.
Translated on 23-10-2026, 7:02.
Gremlin
Post02-07-2004, 8:56    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
which I consider to be more likely the cause:
with chip tuning from ********
Over-injection can lead to thermal problems.
Nevertheless, fuel injectors are wear-and-tear parts that should be regularly checked.
CU Gremlin.
Weini
Post02-07-2004, 9:34    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
I can't imagine that it's related to the chip tuning. icon_biggrin.gif I've had the chip installed for 210,000 km now, and I'm completely satisfied with it. icon_exclaim.gif
Yes - nozzles are definitely wear parts!. I completely agree with that, and replacing them after a certain amount of use (as can be seen) is definitely recommended! }
Weini
Translated on 23-10-2026, 7:03.
Rudi
Post02-07-2004, 10:46    Subject: Fuel Injectors at 239,000 km: Photo. Quote
Today, I replaced the 3 fuel injectors in my Audi 80 TDI (1Z), which is now 12 years old...
Why only three???
Do yourself (or your engine) a favor and replace the fourth one too.
Otherwise, these are nice pictures for the 'Why should I do this or that on a TDI?' collection. They fit well with the AGR pictures.
Best regards, Rudi.
Translated on 23-10-2026, 7:04.
Weini
Post02-07-2004, 13:29    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
Why only three????
Because the needle lifter failed about a year ago (it was making strong, jerky movements) and has already been replaced.
Visually, it didn't look nearly as bad as the three nozzles do now.
Interestingly, the NHG (noise, vibration, and harshness) and the clutch master cylinder were the ONLY icon_exclaim.gif parts that have failed so far. We've had 1 exhaust pipe, 1 water pump, 1 clutch, 1 wheel bearing, etc. And that's after 12 years!
Translated on 23-10-2026, 7:06.
Obermeister
Post02-07-2004, 17:23    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
I once read that someone cleaned their fuel injectors in an ultrasonic cleaner.
Will it make a difference?
Dripping nozzles certainly won't fix the problem, but what about carbon buildup?
Does anyone have information about the cost-benefit analysis?
Translated on 23-10-2026, 7:07.
joergs
Post02-07-2004, 17:28    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
@obermeister
'The ultrasonic cleaner might dissolve the Siff, but with that kind of mileage, the springs will be worn out, the drill bits will lose their sharpness, and so on. At that point, the ultrasonic cleaner won't help anymore...'
Translated on 23-10-2026, 7:08.
D.
Post02-07-2004, 18:06    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
I've been thinking about it for a long time. But, as you also mentioned, everything is still working perfectly: no smoke, low fuel consumption, and good performance.
Have you noticed any tangible changes since the switch?
Joohn
Post03-07-2004, 13:48    Subject: Fuel Injectors: 239,000 km / 148,000 miles Quote
What kind of gasoline do you usually use? Aral, Shell, Esso, etc.?
Translated on 23-10-2026, 7:09.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Engine Performance Issues After 75k Miles? Diesel Engine Technology
No new posts VW T4: 40,000km with loose timing belt Diesel Engine Technology
No new posts Clutch Worn Out After 14,000 km? Diesel Engine Technology
No new posts Engine Failure: AFB, 3 Years, 125,000 km Diesel Engine Technology
