Intercooler: How Much Does It Really Heat Up?
Post30-07-2004, 12:20    Subject: Intercooler: How Much Does It Really Heat Up? Quote
The supercharger's performance is determined by the volumetric flow rate multiplied by the pressure increase.
Taking into account the density and heat capacity of the air, this results in a temperature increase of approximately 75K per bar of boost pressure - without any external heat input or removal.
Now, the loader on the compressor side doesn't just produce useful work.
The compressor performance maps indicate efficiency peaks around 75%, assuming an average efficiency of 73% across all operating conditions.
So, if 73% of the energy fed into the compressor is converted into compression, where does the remaining 27% go?
Normally, this loss of power is converted into useless heat... and where does that heat go in the charger?
I suspect it's due to the heat in the intake air, in addition to the heat generated by compression.
A 100% / 73% ratio results in a loss factor of approximately 1.37, which would need to be added to the temperature increase caused by compression to calculate the actual temperature increase.
So, 75K / bar * 1.37 = 103K at 1 bar... that's already quite a lot for the VP-TDIs icon_eek.gif.
At a power level of 96 kW with a boost pressure of 1.3 bar, the total output is already around 134 kW, plus the respective ambient temperature.
That means that at an air temperature of 30°C, the charge air exits the turbocharger at approximately 164°C.
Is this generally correct, or have I made a mistake in my thinking or calculation somewhere?
Translated on 03-10-2026, 13:17.
Gremlin
Post30-07-2004, 15:45    Subject: Intercooler: How Much Does It Really Heat Up? Quote
What is the basis for the efficiency, i.e., what is the reference value?
75% of the power comes from the exhaust gases?
or something else?
CU Gremlin.
Translated on 03-10-2026, 13:19.
Post30-07-2004, 16:52    Subject: Intercooler: How Much Does It Really Heat Up? Quote
Gremlin wrote:
What is the basis for the efficiency, i.e., what is the reference size?
75% of the power that is introduced through the exhaust?
AFAIK, the identification fields in question only refer to the compressor side.
Mass flow (towards the motor) - Pressure ratio (inlet / outlet) - Compressor speed - Impeller blades (these shell-like shapes).
The reference value should therefore be the power or energy that enters the compressor through the charging shaft.
Regardless of the efficiency of the exhaust gases -> turbine on the hot side...
Translated on 03-10-2026, 13:20.
Post31-07-2004, 7:29    Subject: Intercooler: How Much Does It Really Heat Up? Quote
I found something that might provide an answer.
http://members.aon.at/dihaider/Ladeluftkuehlung.html
(by the way, the whole website is quite informative...)
. . . but what does this "k" with the value 1.4 icon_question.gif mean?
Translated on 03-10-2026, 13:21.
SeatArosa1.7SDI
Post31-07-2004, 9:06    Subject: Intercooler: How Much Does It Really Heat Up? Quote
Hi!
To verify your assumption, simply install a temperature sensor in the intake manifold. You can find various kits with digital displays at any electronics retailer.
Translated on 03-10-2026, 13:22.
Post31-07-2004, 11:59    Subject: Intercooler: How Much Does It Really Heat Up? Quote
I actually didn't want to put in so much effort just to measure things that are already known, and in the process, get more or less inaccurate results. icon_rolleyes.gif
donalexo
Post31-07-2004, 17:09    Subject: Intercooler: How Much Does It Really Heat Up? Quote
@ulfViewing profile: ulf:
mean?
k=1.4 indicates that a polytropic exponent of 1.4 is being used, which implies an adiabatic process.
This assumption is largely correct, provided that the processes occur very quickly, such that there is practically no heat exchange with the surroundings.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 03-10-2026, 13:23.
Post31-07-2004, 20:55    Subject: Intercooler: How Much Does It Really Heat Up? Quote
donalexo wrote:
k=1.4 means that a polytropic exponent of 1.4 is being used in this calculation, which implies an adiabatic process.
icon_idea.gif Thank you, Alex icon_idea.gif.
But now, my initial invoice doesn't seem to be correct anymore.
Haider assumes a compressor efficiency of 75%.
So, based on the rated power, a "loss factor" of 33% is included.
During adiabatic compression, the temperature increases by approximately 75K per bar.
If the additional 33% power loss also contributes to the temperature of the intake air (which it has nowhere else to go), then, in my opinion, this results in a temperature increase of 75K / 0.75 = 100K per bar.
At 1 bar of boost pressure and an intake temperature of 20°C, the charge air would have to exit the intercooler at 120°C.
The Haider diagram, however, only indicates a temperature of approximately 105°C for this.
How is this explained, or where do the missing 15K of warming go? icon_eek.gif icon_question.gif
Translated on 03-10-2026, 13:25.
Uwe
Post01-08-2004, 13:17    Subject: Intercooler: How Much Does It Really Heat Up? Quote
Does it go into the potentially heated exhaust as a loss...?
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 03-10-2026, 13:27.
Post01-08-2004, 14:09    Subject: Intercooler: How Much Does It Really Heat Up? Quote
Uwe wrote:
Do they go into the potentially heated exhaust gas as a loss...?
Hm... by what means?
a) regarding the charger housing -> this would only work if the intake air was hotter than the exhaust gases -> therefore, it's not a viable option.
b) through the charge air cooler into the engine -> then those 15K would have to be measurable in the charge air cooler at the turbocharger outlet - but that's exactly where they are "missing" . . . icon_confused.gif
Translated on 03-10-2026, 13:28.
Uwe
Post01-08-2004, 14:30    Subject: Intercooler: How Much Does It Really Heat Up? Quote
Where do those 33% of efficiency losses go? I don't know either icon_question.gif.
Uwe
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Diesel Engine Misfire: Why It Happens & Fixes On-Board Diagnostics (OBD)
No new posts Charge Air Cooler: Buy Now & Save! Diesel Engine Technology
No new posts Intercooler Logs: PD & VP Performance Data Diesel Engine Technology
No new posts Turbocharger Noise: Causes & Solutions Diesel Engine Technology
