Replace coolant hose (AFN)
Klausel
Post30-07-2004, 22:48    Subject: Replace coolant hose (AFN) Quote
Hello!
AFN in Golf III, year 1997.
From the coolant balance tank, 2 hoses exit -
The first one sits deep (below water level) and disappears towards the back/down.
The second one starts significantly above water level and features (clearly visible from the front)
between the radiator tubes, into the cooling circuit.
This last hose has a deep scratch (caused by a weasel or
Scratch damage from the protective plastic film). Can I do it without any problems?
switch or does a lot of water and air come up
(Coolant ventilation, etc.)?
OT:
I actually had this second-mentioned hose in my workshop today for...
Order placed - however, fate had it that now the aforementioned
First hose is new (invoice for 98 EUR, including venting, pressure check, etc.).
Although I received my money back, the master said, during the replacement appointment for
the other hose, he will mistakenly install (selling price approx. 10 EUR)
replace my (intact) old one - strange feeling, when then under
(defective) assembled, to be disposed of parts, my old, still intact ones
to be extracted and installed
I definitely don't dare to go there anymore...
Question from above not forgotten, Thank you.
Hello, Klaus
No new posts Thermostat öffnet nicht, Kühlwasserschlauch bleibt kalt Diesel Engine Technology
No new posts AVF Kühlmittelregler erneuern Diesel Engine Technology
No new posts Kolbenringe erneuern? Bei Audi 2,5l AEL/AAT Diesel Engine Technology
No new posts 1Z Zahnriemenwechsel. Was gleich mit erneuern? Diesel Engine Technology
