Coolant Error: Check Coolant Level Now
Troubleshooter
Post28-01-2005, 13:52    Subject: Coolant Error: Check Coolant Level Now Quote
Hey guys,
My Golf has recently started displaying an error message:
STOP: Check coolant level. See operating manual.
The warning only appears when the engine is cold, and it goes away after a few hundred meters. There's definitely enough G12 coolant in the system, and I think it's probably a sensor issue. I would appreciate any tips anyone might have.
Best,
Greetings,
Cheers,
Warmly,
Sincerely,
Best wishes,
Kind regards,
All the best,
Take care,
Love,
XOXO,
Hugs,
See you soon,
Talk soon,
Looking forward to hearing from you,
Hope this finds you well,
Have a great day,
Have a nice weekend,
Best,
Translated on 07-09-2026, 14:35.
Post28-01-2005, 13:54    Subject: Coolant Error: Check Coolant Level Now Quote
How about you take a look at the coolant reservoir?
Translated on 07-09-2026, 14:36.
Post28-01-2005, 13:56    Subject: Coolant Error: Check Coolant Level Now Quote
It can only be due to a sensor, specifically one located in the balancing tank.
Check the connector and cable routing, clean the sensor if necessary, or replace the expansion tank.
The coolant level is determined by measuring conductivity, so a dirty sensor will trigger a false alarm.
//edit: Rainer was faster. icon_smile.gif
Translated on 07-09-2026, 14:37.
Troubleshooter
Post28-01-2005, 20:39    Subject: Coolant Error: Check Coolant Level Now Quote
Thanks, guys, that's all.
I cleaned the sensor (the wire clip) in the coolant reservoir using an old toothbrush, and the annoying beeping stopped.
Thank you for the tip.
Best,
Greetings,
Cheers,
Warmly,
Sincerely,
Best wishes,
Kind regards,
All the best,
Take care,
Love,
XOXO,
Hugs,
See you soon,
Talk soon,
Have a great day,
Best,
Translated on 07-09-2026, 14:38.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Low oil pressure warning briefly appears in the driver i... Diesel Engine Technology
No new posts Inspect AHU Diesel Engine Technology
No new posts LWR Sensor Check: How to Test & Diagnose On-Board Diagnostics (OBD)
No new posts Check Catalytic Converter: Symptoms & How To Diesel Engine Technology
