What tire size for 7J x 16 original? Audifelt
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
mk12
Post06-07-2002, 17:13    Subject: What tire size for 7J x 16 original? Audifelt Quote
Hello!!!
What is the maximum tire size I can fit on the original [vehicle/rim/etc.]? Audifelge (5 stars) - are you talking about driving?
The standard tires that come installed from the factory are 205/55 R16.
Can I also use tires with a size of 215 or 225, and will the TÜV (German technical inspection agency) approve them?
Thank you in advance.
Translated on 04-07-2026, 20:35.
davidshoes
Karma: +6 / -2   Thank you, like it!
Post09-07-2002, 17:02    Subject: What tire size for 7J x 16 original? Audifelt Quote
Hi, a different tire size on the 7J rims won't make much of a difference and would definitely require approval from the TÜV (German technical inspection authority). I have 205/55 tires on my A3 with 7.5Jx16 rims for the summer, and you have the same size on your rims. If you measure the contact patch of the tires, they are 1cm wider on the 7.5J rims. On our A6, we have 215 tires on the 5-arm wheels, and they are not significantly wider than the 205 tires I have.
Translated on 04-07-2026, 20:37.
Steffi H.
Post10-07-2002, 10:51    Subject: What tire size for 7J x 16 original? Audifelt Quote
I have 215/40 size Toyo tires on my 7 x 16 inch Seat rims.
Steffi H.
No new posts orig. Freisprecheinrichtung ersetzen Diesel Engine Technology
No new posts Gibt es ein "orig." EMS 240mm für 2.0TDI 16V BKD Diesel Engine Technology
No new posts What is the {CHARGE PRESSURE} indicator? Diesel Engine Technology
No new posts Welche Ölviskosität? Diesel Engine Technology
