Rust on a 1999 Passat Variant
Stefan.TDI
Post07-07-2002, 13:54    Subject: Rust on a 1999 Passat Variant Quote
Hello everyone,
Recently, I noticed rust on the door frame, specifically the window frame, of my Passat. The rust seems to be coming from inside and pushing through the paint. It's almost always located near a seal. Has anyone else experienced something similar? What are the chances of getting it covered under warranty? I have a 10 (or maybe 12) year warranty against corrosion, but it hasn't completely rusted through yet.
I would appreciate any tips you can offer.
Stefan.
Translated on 19-07-2026, 23:19.
Werner
Post07-07-2002, 20:29    Subject: Rust on a 1999 Passat Variant Quote
Hello Stefan,
I can't give you any specific advice, but I noticed the same thing a few weeks ago (my car is from February 1998). I'm going to take it to Volkswagen to have them check it out.
Best regards, Werner.
Translated on 19-07-2026, 23:20.
Karma: +805 / -0   Thank you, like it!
Post08-07-2002, 9:26    Subject: Rust on a 1999 Passat Variant Quote
"Sounds terrible! Are you sure it's not weld points or something like that? Did you already scrape off the paint, and is there really rust underneath?"
Could you please provide me with your vehicle's VIN (Vehicle Identification Number)? It would be helpful for identifying the production location; the VIN is usually found at the front of the service booklet.
Translated on 19-07-2026, 23:21.
Tortsch
Post08-07-2002, 11:55    Subject: Rust on a 1999 Passat Variant Quote
'I've also discovered some rust on my G4, which is a 1998 model. I might also take it to a VW dealership for an inspection.'
Tortsch.
Translated on 19-07-2026, 23:22.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C, 11 months old, rust... Transmission, Chassis, Body & Interior
No new posts Passat Variant 2000: 130 HP Specs & Info Diesel Engine Technology
No new posts Mass Air Flow Sensor Problem: VW Passat Variant 2.5 TDI Diesel Engine Technology
No new posts Passat Variant: Brake Caliper Piston Problems Transmission, Chassis, Body & Interior
