nermin Guest
19-08-2004, 10:32 Subject: Label File: Definition and Usage |
Hello everyone.
'Can anyone provide me with the address of the label file? I need the datai file for the VW alarm system in a Golf 3 from 1999. I've already searched for the address of the label file in the forum and read that the horn can be turned on or off with the correct label file.'
Translated on 30-09-2026, 14:26.
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
19-08-2004, 11:38 Subject: Label File: Definition and Usage |
The label files typically only serve to 'label' the values from the measurement data blocks of the control units.
What you probably want to do is enable a "confirmation beep" when the DWA is turned on.
Where can I find a Golf 3 (Mk3) manufactured in 1999?
Translated on 30-09-2026, 14:27.
Profile PM WWW Garage |
nermin Guest
19-08-2004, 19:25 Subject: Label File: Definition and Usage |
I have a Golf 4, model year 1999. I need information on how to configure the horn so that it beeps once when locking the car with the remote, and twice when unlocking it. Thank you.
Translated on 30-09-2026, 14:28.
19-08-2004, 19:38 Subject: Label File: Definition and Usage |
Quote: | 46 - Central Convenience: -- KWP1281
Only applicable to vehicles with power windows. Compatible with VAG-COM. Numerous options and features can be configured.
Selective Unlocking:
[Select]
[46-cent. Conv.] (35-cent. Locking for manual window cars)
[Recode - 07]
text
Write down the existing code for future reference.
Enter the 5-digit code from below.
[Do It!Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Look at the existing code. If you have selective unlocking (pressing the unlock button on the remote once opens the driver's door, twice opens all doors), the last digit of your code should be an even number. To unlock all doors, add 1 to the code.
Okay, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064), add one to make it 00065 so that all doors unlock with one press of the unlock button.
Lock/Unlock Horn/Flash:
[Select]
[Adaptation - 10]
Channel (03..0
Adaptation Value (1 = on, 0 = off)
[Save]
Channel 03: Automatic Lock.
Channel 04: Automatic Unlock.
Channel 05 Unlock, horn sounds.
Channel 06: Lock, horn sounds.
Channel 07 Unlock, turn signals flash.
Channel 08 Lock, turn signals flashing.
Source: http://www.ross-tech.com/vag-com/cars/vwmkIV.html
Translated on 30-09-2026, 14:30.
