Wurstblinker Guest
24-08-2004, 12:05 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi there,
Does anyone else experience this problem, and can someone tell me what I need to do about it?
Do you need to replace a relay?
The preheating light stays on constantly, and the car itself seems to be overheating.
You're welcome.
Sausage blinkers.
Translated on 16-07-2026, 7:14.
dieter Profi-Schrauber
Joined: 01/27/2003 Posts: 270 Karma: +13 / -0 Location: LK Uelzen
24-08-2004, 12:10 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi there,
If it fails to start, the temperature sensor might be disconnected or faulty, or the glow plug relay could be malfunctioning.
Greetings,
"Dieter"
T3 syncro 16 AFN
Translated on 16-07-2026, 7:15.
Wurstblinker Guest
24-08-2004, 12:39 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Hi Dieter,
'Where is the temperature sensor located, and how can it be tested? The warning light goes off after starting the engine.'
Thank you.
Sausage blinkers.
Translated on 16-07-2026, 7:16.
24-08-2004, 15:28 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
If everything is original, this is one of the two sensors located on the sides of the ZK (likely referring to a control unit or device). The other one is for the temperature display. The third sensor at the front of the ZK is for the after-run pump. One of the cables should be blue/white. Unfortunately, I can't find any resistance values for this sensor. If the sensor has infinite resistance, it is definitely defective. But maybe the cable is just disconnected.
Greetings.
"Dieter"
T3 syncro 16 AFN
Translated on 16-07-2026, 7:17.
24-08-2004, 15:51 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
I once "cooked out" the sensor – meaning I recorded its characteristic curve while it was bubbling in a pot  .
If I can still find it, I might be able to include it inline  .
The colleague's name is 049 919 501 and can be adopted at any Volkswagen dealership for €22.
Translated on 16-07-2026, 7:18.
Profile PM Garage |
Wurstblinker Guest
24-08-2004, 15:59 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Are you referring to one of the temperature sensors located on the water flange of the cylinder head?
Then I'll go ahead and replace it.
Sausage blinkers.
Translated on 16-07-2026, 7:19.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
24-08-2004, 16:37 Subject: VW Bus T3 with 1.6 TD JX engine glows forever! |
Willst Du ihn nicht erstmal messen und das Kabel prüfen?
Profile PM WWW Garage |
