MFA: 3x Higher Than Average Consumption
DeathAngel69
Post05-07-2002, 8:56    Subject: MFA: 3x Higher Than Average Consumption Quote
Hello everyone.
I bought a Passat 35i, model year 1992. It has been modified with a 1.9 TDI engine (engine code: 1Z), which is approved by VW. It's working well overall, but the MFA (Multi-Function Display) shows an average fuel consumption of 18-22 liters per 100 km. The actual fuel consumption is 6.72 liters per 100 km, according to the last fuel tank reading.
Can anyone give me a hint about what's ahead?
The speedometer is from a 2.0L 16V gasoline car. There's also this vacuum transducer still connected at the back, which was previously used for the MFA. Could it be related to that?
Translated on 10-09-2026, 12:18.
Michael II
Post05-07-2002, 9:29    Subject: MFA: 3x Higher Than Average Consumption Quote
The instrument cluster (likely from the 1992 model year?) is not yet diagnosable. Therefore, you cannot fix it by reprogramming (which is not possible with newer instrument clusters). You will need to find a suitable replacement instrument cluster.
Tschüss
Michael II
Translated on 10-09-2026, 12:19.
DeathAngel69
Post05-07-2002, 12:55    Subject: Damn! Quote
Thank you for the reply. Yes, it's a 1992 model.
Unfortunately, I had actually expected something more positive icon_smile.gif)))
But what can't be done, can't be done.
Translated on 10-09-2026, 12:20.
No new posts Audi A2: Dashboard shows only range Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Measurement Block 13: What Does It Show? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Fuel Injection Timing: Diagnostic Tool Results Diesel Engine Technology
No new posts Bordspannungsanzeige im Kombiinstrument zeigt zu viel an. Diesel Engine Technology
No new posts The display in the instrument cluster is not showing anyt... On-Board Diagnostics (OBD)
