14-04-2004, 21:12 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
There's news! Uwe Ross sent me a sample of the professional adapter for KKL+CAN that is currently under development.
This now also removes any obstacles to diagnosing newer vehicles such as the Touran, Golf5, etc., where most control units can only be accessed via the CAN bus.
Let's see how the initial tests go. If anyone in the Nuremberg area is interested in testing this product, please feel free to contact me.
Profile PM WWW Garage |
Marco Guest
21-04-2004, 21:25 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Hi Rainer,
What will that part cost?
21-04-2004, 21:29 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Hi Marco,
"Sorry, I can't give you a price just yet..."
Currently, the adapter (prototype) is being loaned out for testing. If you are interested, please send me a private message or email!
joergs Guest
25-04-2004, 13:31 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
'The interface is so awesome! Even the ABS in my old Passat 35i with a 1Z engine, which often malfunctions with the MAX232 adapter and requires lowering the baud rate to diagnose, works flawlessly with this. It's also impressive how quickly the connection is established!'
@uwe@rosstech
When do you think the KKL-CAN interface will be available in Germany?
Uwe@Ross-Tech Guest
25-04-2004, 20:36 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
I'm unable to provide a good answer because dealers in Germany usually don't order their interfaces through us, and the +CAN interfaces are not yet available in large quantities. It should get better next month.
However, when using connections on port K, the CAN interface functions exactly the same as our HEX-USB (or serial HEX-COM). So, when it comes to vehicles that don't use the CAN bus, a standard HEX interface (which we've had in our product line since the end of 2002) is just as fast and reliable.
However, anyone who has already purchased a valid VAG-COM license (and can prove it) can also purchase interface upgrades from us. For example, a HEX-COM interface as an upgrade costs $179, or approximately 152 euros. With CAN support, the price increases by approximately $50 (42 euros).
-Uwe-
PowerSound3L Guest
27-05-2004, 0:35 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
hi,
CAN bus is already on its way out.
What follows is TTP. Time-triggered protocol.
Just for the sake of it.
greetings
Jan6K
27-05-2004, 7:09 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
May I ask for a source?
IMO, besides DC, no one has seriously worked with TTP, and even they wanted to switch to ByteFlight/FlexRay... and now they are continuing with CAN.
Jan.
1Z5 CFHF  / AHB H4D
Uwe@Ross-Tech Guest
05-06-2004, 1:57 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
hi,
greetings
The specific data buses used internally within a car are not relevant. For example, almost all VW/Audi models since 2000 have internal CAN buses, but diagnostics have been performed via the K-line up until now.
'Diagnosis via CAN is a worldwide standard. Starting with the model year 2008, it is even mandatory for generic OBD purposes.' 'So, diagnosis via CAN is the future!'
-Uwe-
Brunhilde Guest
06-06-2004, 13:46 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
What @PowerSound3L is writing likely has more to do with the future control of electrical components in vehicles. All devices will now be connected using a single serial two-wire connection.
'For some time now, several manufacturers have been working on connecting the control of all electrical devices (including lights) through a central protocol, so that they can be connected with only power (+ & ground) and a single control line.'
However, this requires that each device has a logic implemented that automatically detects when it should be turned on or off.
However, the external diagnostics will continue to be based on the CAN protocol.
22-07-2004, 9:46 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Professional systems with CAN bus support are now available! HEX-USB+CAN HEX-V2:
VCDS Interface Upgradehttp://shop.dieselschrauber.de/product_info.php/products_id/46{MARKER}
This enables the diagnosis of control units in the following new vehicle models: Audi A3 & A8 (manufactured from 2004), Audi A6, Skoda Octavia, Seat Altea (from model year 2005), Golf V, and Touran.
Best regards, Rainer.http://shop.dieselschrauber.de/product_info.php/products_id/329
Dieselhatza Guest
04-09-2004, 21:07 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Very silly question:
I also have the option of diagnostics via CAN, in addition to the K-line, on a brand new Fiesta (Ford  ). What happens if I buy the device, and what software will it work with?
Georg.
04-09-2004, 21:44 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Hi Georg,
I think things look bleak for Ford, because you would first need software that can also address the CAN functions of the adapter.
Perhaps Uwe (Ross) knows more about this.
herwigw Guest
08-09-2004, 10:59 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Sorry for the probably silly question, but does that mean the professional adapter...?
* Only applies to new model lines.
or
* Both older models (e.g., my Bora from 2000) and newer models can (use a connection with two plugs or similar).
Best regards.
herwig
08-09-2004, 11:48 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
Rainer K. wrote: | Professional systems with CAN-Bus support are now available for delivery!
Bitte gib den Text an, den du übersetzt haben möchtest.
With this, there are no more obstacles to the diagnosis of control units in the new Audi A3 & A8 models manufactured from 2004, Audi A6, Skoda Octavia, Seat Altea from the 2005 model year, Golf V, and Touran. |
...and possibly other ("older") models, such as the Polo 9N (-> air conditioning):
Okay, I'm ready. Please provide the German text you want me to translate.
Profile PM Garage |
08-09-2004, 12:19 Subject: Diagnosis via CAN, HEX-USB+CAN / MicroCAN |
The HEX-USB+CAN supports CAN, which is an additional feature in addition to K- and L-line support.
