Vag-COM values
btreyer
Post26-08-2004, 14:18    Subject: Vag-COM values Quote
Hello everyone,
I'm new here and I have a Golf manufactured in 2002-2003 with a 74kW AXR engine.
Using VAG-COM in module 17 (instrument cluster), the value 32000 appears in channel 50 under 'Adaptation'. What does this value mean?
Is there a list that explains the values of the individual channels of the engine control unit? Unfortunately, I haven't found anything yet.
I've heard that certain values, such as boost pressure and injection timing, can be adjusted within a certain range using VAG-COM. Is that true?
btreyer
Translated on 09-07-2026, 9:02.
Michael II
Post26-08-2004, 15:15    Subject: Vag-COM values Quote
Please use the search function. That should keep you busy for a while...
Bye.
Michael.
Tschüss
Michael II
Translated on 09-07-2026, 9:03.
Marco
Post26-08-2004, 15:35    Subject: Vag-COM values Quote
Hi Michael II,
Welcome back!!!
joergs
Post26-08-2004, 16:37    Subject: Vag-COM values Quote
@michaelII
It's so good to hear from you again!!!!!!
Avatar-Jan6K
Post26-08-2004, 17:29    Subject: Vag-COM values Quote
Hi MichaelII,
Also from me as well: Welcome back!
Jan.
1Z5 CFHF / AHB H4D
Post26-08-2004, 18:17    Subject: Vag-COM values Quote
@MichaelII
Translated on 09-07-2026, 9:04.
Post27-08-2004, 17:36    Subject: Reading suggestion for the questioner... Quote
/viewtopic.php?t=439&highlight=adaptation
Okay, hier ist die Übersetzung:
"Try using the search function with the keyword 'Adaption'."
seat_ibiza83
Post01-09-2004, 18:29    Subject: Explanation of adaptation Quote
I cannot tell you what the number 32000 means in Adaptation when it is less than 50.
I can only say that it's available under the correct VAS diagnostic device.
17 Dashboard - 10 Adaptation - blocks for resetting the service interval on all new VW and Audi models.
Block 45 indicates the quality of the oil, whether it's long-life or standard.
'In this context, the values 0 and 1 are considered normal, while any value above that is classified as 'longlife'.'
For older models, i.e., those produced before 2000, it's block 10 with a value of 15.
Block 11 with the value 30.
and Block 12 with the value 35.
The respective numbers indicate the intervals for oil changes and servicing.
For the older A8 model, the values are the same from block 06-09, except for block 09, which receives the value 72, indicating the brake fluid change interval.
Best regards.
luc
Translated on 09-07-2026, 9:06.
No new posts AGR values OK? On-Board Diagnostics (OBD)
No new posts AGR, LMM & VAG-COM: Explained & Troubleshooting On-Board Diagnostics (OBD)
No new posts VAG-COM Values: LM (Longitudinal Acceleration) On-Board Diagnostics (OBD)
No new posts Fluctuating LMM Values: Causes & Solutions Diesel Engine Technology
