Retrofitting S-contact, what is the effort required?
golf3schrauber
Post08-09-2004, 6:38    Subject: Retrofitting S-contact, what is the effort required? Quote
I would like to retrofit the S-contact on the ignition lock of my Golf.
What exactly needs to be changed?
Is it sufficient to replace both the ignition switch and the locking cylinder together within the ignition switch housing? Or must the housing also be replaced on the steering column?
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Automatic Transmission Leak: $2000 Repair Cost? Transmission, Chassis, Body & Interior
No new posts Hydraulic lifter replacement: cost & effort. Diesel Engine Technology
No new posts Contact for broken horn Diesel Engine Technology
No new posts A3 8P Relief relay X-contact problem... On-Board Diagnostics (OBD)
