I would like to retrofit the S-contact on the ignition lock of my Golf.
What exactly needs to be changed?
Is it sufficient to replace both the ignition switch and the locking cylinder together within the ignition switch housing? Or must the housing also be replaced on the steering column? Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
