Golf TDI Gear Stick Loose - Fix It!
Maik
Post09-09-2004, 9:14    Subject: Golf TDI Gear Stick Loose - Fix It! Quote
Hello.
Since there were so many answers for the Jetta, I hope you can help me too. icon_wink.gif
In my Golf3 (built in 1994), the shifting doesn't feel precise anymore; it feels quite spongy. icon_lol.gif It's not as well-defined as it was 10 years ago. Is there a part that can be easily replaced, or do I have to delve into the gearbox?
Thank you very much and best regards.
Maik.
Translated on 17-08-2026, 10:04.
Post09-09-2004, 9:29    Subject: Golf TDI Gear Stick Loose - Fix It! Quote
You can often get rid of some issues by taking a look inside the knob assembly (the plastic or leather part underneath the knob) and observing the mechanism within.
For example, I clamped a 1 mm sheet of metal to the longitudinal axis to eliminate any play in that area.
I also put something in between the cross axle (where the plastic cross is attached) to reduce the play.
Unfortunately, the rubber grommet at the front of the gearbox (which is part of the shift cable) has some play – but there are two versions available, and they aren't sold separately.
The cable has no slack, but that's because of the redirection mechanism located at the front of the gearbox icon_sad.gif.
http://www.luxus-wg.de/~martin/auto_bilder/schalt.jpg
Translated on 17-08-2026, 10:05.
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Jetta TD: Loose Gear Shift Lever Problem Diesel Engine Technology
No new posts Turbocharger Issues: How Much Can It Cost? Diesel Engine Technology
No new posts Golf 2 front axle, excessive play Transmission, Chassis, Body & Interior
No new posts Golf 4 driver's seat has play - Solution, Cause? Transmission, Chassis, Body & Interior
