Battery Terminal Connection to Alternator: Fake?
DeathAngel69
Post05-07-2002, 13:03    Subject: Battery Terminal Connection to Alternator: Fake? Quote
My 120A alternator doesn't have a DF terminal, or am I just being stupid? Is it possible to get the 'FAKEN' signal somehow? Maybe by using a resistor or tapping into something without connecting directly to the main terminal?
What kind of signal comes from the DF terminal?
Translated on 22-08-2026, 15:07.
Post05-07-2002, 16:48    Subject: What problem do you have? Quote
Hi.
In my bra, the data connector pin is located inside the double plug with the thinner wires (the other wire leads to the charging indicator).
Why do you even want to work in that field / what's your problem?
Oh yes, I almost forgot: The DF terminal provides information about the current load on the alternator.
When the charge reaches 100%, for example, in winter, the engine computer may turn off the glow plug heating, because being colder for longer is still better than a dead battery icon_wink.gif.
Translated on 22-08-2026, 15:09.
DeathAngel69
Post06-07-2002, 10:30    Subject: Best German Coffee: Buy Online & Enjoy! Quote
Exactly because of the preheating function. Mine doesn't do it new_cry.gif.
'Because according to the EDC (Electronic Diagnostic Control), the signal from the alternator's voltage regulator is missing. That's why it's not working, and it should be functional in winter. I don't want to have to run the auxiliary heater constantly.'
Okay, I'll trace the cable now. Thanks for the kind reply.
Have a nice day.
See you tomorrow.
DeathAngel.
Translated on 22-08-2026, 15:10.
DeathAngel69
Post08-07-2002, 17:17    Subject: Still Available: Find It Now! Quote
Hello.
Okay, I've examined my power supply unit (PSU). It only has a 'W' connector and a 'D+' connector.
How can I fix this error? Where am I supposed to get the signal from? I don't want to replace the alternator. It's a nice 120A alternator, after all.
Translated on 22-08-2026, 15:12.
Post08-07-2002, 17:28    Subject: Faulty Alternator? Symptoms & Causes. Quote
Hi.
AFAIK, the terminal for the tachometer is different on "mechanical" diesel engines, so the part you have is probably not compatible with your TDI.
The load is generated by the runner voltage and can therefore be measured across both brush holders.
One of them is either controlled by the mass or battery positive terminal, while the other is controlled by the regulator. You can tap into the load signal there.
The question is whether it has the correct polarity for the motor computer, i.e., whether the unswitched coil is connected to + or -. . . icon_sad.gif
With incorrect polarity, the system will likely detect the opposite of the actual load level (high instead of low, and vice versa).
Then, perhaps an intermediate inverter stage could help (e.g., a transistor in an emitter configuration)... but that is purely theoretical!
Translated on 22-08-2026, 15:13.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
