Tire Gas Scam: Is It a Ripoff or Nonsense?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
ObenbeiMutti
Post12-08-2004, 16:04    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
Hello.
Recently, while buying tires...
...I was persuaded by the salesperson's overwhelming arguments in favor of it to get a gas refill icon_redface.gif.
Based on his description of the properties, I assumed it was something like xenon atoms or an expensive, high-tech industrial gas with large molecules (which would at least justify the price).
icon_eek.gif But, I'm looking at icon_eek.gif, nitrogen. Just plain, cheap stuff that surrounds me 70% of the time.
Nitrogen.
After refilling the air at most three times, assuming it's not volatile as promised, there would only be 'noble gas' left in the tire.
I feel like I'm being taken for a fool!
I hope I'm right to feel this way. I would appreciate feedback from knowledgeable forum members who can either support my concerns or offer a more balanced perspective.
Tobi.
Translated on 10-08-2026, 7:36.
Jürgen
Post12-08-2004, 17:15    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
IMO, this is clearly a rip-off. The nitrogen filling is supposedly intended to prevent pressure loss.
to be minimized. Based on my experience, these issues persist as long as the tires, rims, and...
Valves are usually in good condition, but that's the minimum requirement. In my over 30 years of experience...
It's rare to find a car with a full spare tire. Regularly checking your tire pressure is also important.
Nitrogen filling is essential, and it's also cheaper than these!
'P.S.: For commercial aircraft, the tires on braked wheels must be...'
(For cylinders only connected to the main landing gear), must be filled exclusively with pure nitrogen.
will be implemented. The reason for this is to minimize the risk of fire during heating.
or cause the brakes to overheat. Even with nitrogen filling, periodic...
Tire pressure checks are mandatory - for example, on an Airbus, they must be performed every 72 hours!
Translated on 10-08-2026, 7:39.
Gremlin
Post12-08-2004, 19:19    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
I always check the pressure whenever there's a significant temperature change.
Since I often cut corners and rush things, even a small amount too much or too little can be noticeable.
Absolutely awesome on the motorcycle...
I think pure N2 is nonsense... if the tire is okay, very little air will leak out. And I'm not going to let some wannabe chemist tell me that I never have to check the pressure again icon_exclaim.gif.
CU Gremlin.
Translated on 10-08-2026, 7:41.
Post12-08-2004, 20:46    Subject: Tire Gas Scam or Nonsense? Quote
Nitrogen.
Tobi
"In my humble opinion, the nitrogen content of the air is actually 78%..."
Translated on 10-08-2026, 7:42.
Julian
Post13-08-2004, 8:55    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
It's not worth it. Tire pressure still needs to be checked regularly. And... why pay for something that is freely available at every gas station? icon_smile.gif
Translated on 10-08-2026, 7:43.
faz
Avatar-faz
1994 Audi 80
Post13-08-2004, 9:04    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
A small amount of pure nitrogen already makes a difference...
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 10-08-2026, 7:44.
Gremlin
Post13-08-2004, 9:21    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
So gesehen... we have a 25,000-liter liquid tank behind the building http://www.cheesebuerger.de/smilies/frech/18.gif.
CU Gremlin.
Bee
Post08-09-2004, 16:36    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
Hi everyone,
Based on my own experience, I can say that filling with gas really makes a difference!
Duck and cover.
As I mentioned before: Air contains 78% nitrogen. The remaining molecules are larger than nitrogen. Therefore, it doesn't make sense to me why a nitrogen filling could have any advantages at all. Even if I drive a tire hot: It won't get so hot that it burns. If the brakes are so hot that a tire ignites, the tire doesn't ignite because of the oxygen *in* the tire, but because of the oxygen surrounding the tire. icon_cool.gif
'Micha'
Translated on 10-08-2026, 7:45.
Forenheini
Post08-09-2004, 17:49    Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? Quote
The only physically justifiable advantage of pure N2 would be a slightly better gas constant, but the difference between the gas constant of air and N2 is in the low single-digit percentage range (I'd have to look up the exact value), so it can safely be ignored.
I always follow this motto: If it's free, why not; otherwise, just leave it be icon_exclaim.gif.
Apart from that, the supposedly very pure N2 fillings are also not 100%. After refilling two or three times at the gas station, even with air, there is a significantly higher proportion of N2 in the tire, if you believe the advertising argument about diffusion (oxygen molecules (O2) aren't that small after all...) and think about it logically icon_exclaim.gif.
Translated on 10-08-2026, 7:48.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The ATU Horror Story! Can so much be broken, or is it jus... Transmission, Chassis, Body & Interior
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
No new posts Oil VW 505.01 or 507.00 Upload
