VAG Injector Pump Part Numbers for 1Z Models
Golfdriver
Post18-09-2004, 17:40    Subject: VAG Injector Pump Part Numbers for 1Z Models Quote
I have a question about the VAG part numbers for the fuel injection pumps used in the 1Z engine.
Are all of these the same pumps, or does the motor come with different pump options?
Can I replace a '028 130 109 H' with a '028 130 110 H' or a '028 130 115 M(X)'?
I'm having a hard time understanding it and I've heard different opinions and statements about it.
Since the engine is always the same, it should work, or does it depend on the control unit?
Thank you for your help.
Translated on 23-07-2026, 23:55.
wolfi_b
Post19-09-2004, 11:08    Subject: VAG Injector Pump Part Numbers for 1Z Models Quote
So, there are (at least) two different types. They have different sensors for measuring the fuel injection amount.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 23-07-2026, 23:56.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Fuel Injector Installation: Tips & Tricks Diesel Engine Technology
No new posts Injector ET Numbers: Find Yours Now! Diesel Engine Technology
No new posts Timing Belt Replacement: 1Z Model Questions Diesel Engine Technology
No new posts Bedeutung der Nummern am Motorsteuergerät Diesel Engine Technology
