Replacement of the upper seal on VP37 injection pump (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
Georg-TDI Post11-10-2004, 9:53
Here, you can download a report of mine in PDF format.
The described repair involves replacing the upper seal between the ESP cover and the MSW on a Bosch VP37 pump.
This article should be interpreted solely as a private report.
All work must be carried out at your own risk and responsibility.
I hereby exclude any liability for any damages that may be caused.
This report was created by Rainer Kaufmann for the forum www.dieselschrauber.de and is intended for internal information sharing within the forum only.
Images and text may only be copied, cropped, quoted, and commented on within this forum.
I will be notified as the author of this article of any further displacement.
Author and copyright holder: Georg-TDI
VCDS can be used to measure the start-stop values of the mass airflow sensor or the injection quantity at idle.
Dichtungstausch_VP37.pdf
 Austausch der oberen Dichtung zwischen ESP-Deckel und MSW der Bosch VP37 Pumpe
 File name:  Dichtungstausch_VP37.pdf
 File size:  420.18 KB
 Downloaded:  31077 times
Ratings - Replacement of the upper seal on VP37 injection pump
Average rating: 4.40 - worst rating: 2 - best rating: 5 - number of ratings: 10 - View ratings
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Leaky ESP: VP37 Injection Pump Repair Diesel Engine Technology
No new posts VP37 Injector Pump: What is the function of this adjuster? Diesel Engine Technology
No new posts Fuel consumption of TDI vs. SDI engines at high load Diesel Engine Technology
This topic is locked, you cannot edit or reply. Reduce Smoke at High RPMs Diesel Engine Technology
