How many WFS chips can a 1Z hold?
Post13-09-2004, 16:12    Subject: How many WFS chips can a 1Z hold? Quote
Hi.
How many keys can I program to a 1Z (with 021 AF, BF, or HD)?
I would like to avoid having my previously saved keys deleted when I add new ones (or at least be warned about it).
"Thank you."
Translated on 28-10-2026, 21:48.
Rudi
Post13-09-2004, 19:23    Subject: How many WFS chips can a 1Z hold? Quote
Hi Martin,
is independent of the engine control unit (ECU). The key data is stored in the vehicle function server (VFS) control unit.
A maximum of eight keys can be paired.
Warning! Every time you pair a new device, all keys must be re-registered.
and you need the number that came with your original keys.
Best regards, Rudi.
Translated on 28-10-2026, 21:49.
Post13-09-2004, 22:03    Subject: How many WFS chips can a 1Z hold? Quote
WFS-STG ???
I thought that had already been integrated into the MSTG (presumably a specific law or regulation) by now (i.e., in 1996)?
And number ??? I don't have a number!!!
In your PDF, there's nothing mentioned about a "number" - it just contains things like "login" and "adaptation," etc.
And now what?
Translated on 28-10-2026, 21:50.
Rudi
Post14-09-2004, 7:53    Subject: How many WFS chips can a 1Z hold? Quote
WFS-STG ???
The WFS (Window Folding System) itself is located in the engine control unit. However, the WFS control module handles the key functions.
and 'allows' the MSTG to virtually start the engine.
In your PDF, there's nothing mentioned about a 'number' - it just contains things like 'login' and 'adaptation,' etc.
The PDF, as far as I recall icon_redface.gif, only referred to the transition to the MSTG.
The number should also be obtainable through the customer service department.
Best regards, Rudi.
Translated on 28-10-2026, 21:51.
No new posts Additional key for Leon - requires a workshop Transmission, Chassis, Body & Interior
No new posts Swap chips On-Board Diagnostics (OBD)
No new posts Replace Engine Control Unit Chip? Diesel Engine Technology
No new posts Clean LMM: How to Clean Your LMM. Diesel Engine Technology
