Passat 3B - Issues with Comfort Control Unit / Instrument Cluster
Go to page: 1, 2  Next
Sundance Kid
Post18-06-2004, 17:35    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
'Recently, I became the proud owner of a 1998 Passat Variant Syncro with an AFN engine. I'm experiencing some issues with the comfort control unit. The previous owner had the multi-function display (with navigation) replaced shortly before selling it to me (part number 3B0 919 890 MX, costing 350 Euros).'
1. I can't pair the remote control.
Ich habe 2 Schlüssel, einen normalen und einen Funkschlüssel. Als ich den Wagen übernommen habe, ließ sich der Motor nur mit dem Funkschlüssel starten. Der freundliche hat den anderen Schlüssel dann der Wegfahrsperre vorgestellt, ist aber beim Anlernen des Funkschlüssels gescheitert. Ich habe seitdem einige Male versucht, mit VAG-COM und der Anleitung „Remote matching“ von Ross-Tech den Schlüssel anzulernen, aber nicht mal ein „Piep“ oder ein Blinken geerntet. Nach den erfolglosen Versuchen steht der Fehler F01179 incorrect key programming 35-00 im Fehlerspeicher. Der Schlüssel sendet, das habe ich überprüft. AußerdeIt worked during the test drive with the old MFA (Multi-Function Display).
2. The channel assignments in the comfort control unit do not match the channel assignments I have found on various websites. In my case, channel 3 is 'Auto Lock,' channel 4 'Auto Unlock' is missing, channels 6 'Horn for unlocking' through 9 'Flashing lights for locking' are shifted down by one (channels 5 through icon_cool.gif, and channel 10 is missing again. However, I can adjust the horn for unlocking, for example.
Does anyone have any ideas on how to get the remote working or what might be broken?
Is it possible that the instrument cluster is incorrect, and how can I check this?
Could it be that the incorrect channel assignment is due to the Syncro system having something different than usual?
Is the comfort control unit integrated into the instrument cluster and therefore has it been replaced?
In my desperation, I wanted to re-initialize the keys with the instrument cluster. On my key card, a 4-digit code is revealed after scratching. However, VAG COM requires a 5-digit or a 7-digit code. How can I proceed?
Thank you in advance for your numerous responses.
Bye.
Translated on 20-07-2026, 1:20.
Post18-06-2004, 19:52    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
How about this?
Translated on 20-07-2026, 1:23.
Sundance Kid
Post18-06-2004, 21:18    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
I expected to be able to ask a question, but I was scolded almost as soon as I did.
'Of course, I'm familiar with those two links, as I've been searching for the solution in the forum for a few weeks now. The guide from Ross Tech that I mentioned in my question is specifically designed for VAG COM, but otherwise describes the same process as the one by Michael II. Unfortunately, neither of them works. That's why I'm at a loss.'
Michael.
Translated on 20-07-2026, 1:24.
joergs
Post18-06-2004, 21:35    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
Who's poking around here?
Translated on 20-07-2026, 1:25.
Post18-06-2004, 22:20    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
I'm also wondering about that icon_confused.gif.
Sundance Kid
Post18-06-2004, 22:50    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
Okay, okay.
It was supposed to be a joke, but I probably used the wrong tone.
Sorry.
Translated on 20-07-2026, 1:26.
Theresias
Post19-06-2004, 13:21    Subject: Re: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
2. Die Kanalbelegung vom Komfortsteuergerät stimmt nicht überein mit den Kanalbelegungen, die ich auf verschiedenen Seiten gefunden habe. Bei mir ist Kanal 3 „Auto Lock“, Kanal 4 „Auto Unlock“ fehlt, Kanal 6 „Entriegelungshupen“ bis Kanal 9 „Verriegelungsblinken“ sind um 1 nach unten (Kanal 5 bis 8 ) verschoben, Kanal 10 fehlt wieder. I can, for example, adjust the door lock confirmation sound.
Is the comfort control unit inside the instrument cluster and therefore has it been replaced?
The comfort control unit is separate. I'm hearing about 'shifted channels' for the first time; based on your description, it seems like you have a completely different software version installed. The missing channel 10 could potentially be explained by a missing vehicle immobilizer (DWA).
What is the part number and software version of your comfort control unit?
Translated on 20-07-2026, 1:27.
Sundance Kid
Post19-06-2004, 14:10    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
Hello Theresias,
The comfort control unit has the following part number from the VAG group:
1J0 959 799 J and is called...
OE Central-SG Comfort 0001.
Soft Coding: 04097, which corresponds to a central locking system (ZV), 4 door handles, and complete door unlocking.
I don't know the software version. How can I find it out?
Goodbye.
Translated on 20-07-2026, 1:28.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post19-06-2004, 14:40    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
Could you please check if the key and the comfort control unit are transmitting on the same frequency? They might not be synchronized, which could explain why nothing is working.
Because a certain change was made starting with a specific production year.
The frequency is written on the key, but you need to check the control unit. icon_rolleyes.gif
B.Eng (FH) u. KFZ Meister
Translated on 20-07-2026, 1:30.
Sundance Kid
Post19-06-2004, 14:47    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
The comfort control unit has not been replaced, and it was working before the instrument cluster was changed. This means that the frequencies must be compatible. I assume that the frequencies cannot be altered.
joergs
Post19-06-2004, 14:52    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
It might be related to the communication between the combination instrument and the comfort control unit. I'm not entirely sure how it applies in your specific case. However, with the Passat 3BG, some of these issues are often caused by communication problems via the CAN bus. If a different combination instrument was installed...
Perhaps this is a starting point.
Translated on 20-07-2026, 1:31.
Theresias
Post19-06-2004, 14:55    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
If there were communication problems, it would switch to single-wire CAN mode and store that information in the error memory.
Sundance Kid
Post19-06-2004, 15:03    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
I don't have a CAN.
Translated on 20-07-2026, 1:32.
Theresias
Post19-06-2004, 15:05    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
I don't have any CAN.
However, communication errors would still be stored in the error memory.
joergs
Post19-06-2004, 15:06    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
Sorry...
Sundance Kid
Post21-06-2004, 20:17    Subject: Passat 3B - Issues with Comfort Control Unit / Instrument Cluster Quote
to add to the confusion:
On the Ross-tech homepage, I found a channel assignment for the comfort control unit that largely matches mine: channels 3 to 8 (except for 4 – which is missing 'auto unlock' in my car) are the same. This applies specifically to vehicles exported to the USA.
Could it be that I got some kind of export version for the Inner Mongolia region? icon_cry.gif
Further oddities:
When I activate 'Auto Lock,' channel 3, the doors lock reliably above 15 km/h. However, when the ignition key is removed, the doors unlock, which is actually what 'Auto Unlock' should do. Additionally, during driving, the doors sometimes lock and unlock randomly for no apparent reason.
I have configured the 'horn activation' feature (set to channel 5 on my system), even though it's not allowed. Sometimes the horn sounds when I turn the key (at the beginning of the unlocking process), and sometimes only after the locks have been unlocked (at the end of the unlocking process).
Is that normal?
Bye icon_wink.gif.
Translated on 20-07-2026, 1:34.
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problems with the comfort control unit On-Board Diagnostics (OBD)
No new posts Location of Comfort Control Unit, Passat 3BG Diesel Engine Technology
No new posts A4/B5: Instrument Cluster Replacement, Seal Issues Transmission, Chassis, Body & Interior
No new posts Passat combination instrument cluster, year 1998 On-Board Diagnostics (OBD)
