Car Radio Error Codes: Meaning & Troubleshooting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
andre
Post29-09-2004, 9:23    Subject: Car Radio Error Codes: Meaning & Troubleshooting Quote
I'm relatively new to the field of diagnostics, but I've managed to do some digging and found the following information 'online':
Control Module Part Number: 1M0 035 186 K
Component and/or Version: Radio GRO 2.29
Software Coding: 00401
Workshop Code: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Okay, so there seems to be something wrong with the antenna. Can someone explain to me exactly what it is?
Is the antenna completely detached, or is there a problem with the power supply?
Can I actually clear the error (in memory)? And if the hardware error isn't fixed, will it reappear (in memory), or will it be gone permanently then?
THX.
Translated on 29-07-2026, 7:00.
No new posts Doku Golf 5, Lautstärke am Radio defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0, Radio schaltet nach Standzeit nicht ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bedeutung der Spurkonstante Transmission, Chassis, Body & Interior
No new posts Meaning of MWB's for the 1.9 TDI AVF engine: On-Board Diagnostics (OBD)
No new posts MWB 3/AGR: Meaning of Duty Cycle Ratio On-Board Diagnostics (OBD)
No new posts Alarm Source Meaning A8 4E On-Board Diagnostics (OBD)
