4-Motion Rear Noise? KW GmbH Fixes It!
CheBu
Post22-09-2004, 8:13    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Hello everyone,
I'm really frustrated with my Bora. It has issues with the door, rear axle mounting, and the last oil change.
I've tried everything to eliminate those annoying noises from the rubber bushings.
Letzte Idee vor der Verschrottung war eine kurze Mail an KW. Die haben die mir am !!! NEXT!!!
"I sent some stainless steel rings today that need to be installed between the spring and the spring seat."
Fazit: Geräusch weg. Mehr als zufriedener Kunde! Great company.
Stefan.
Translated on 12-08-2026, 2:04.
Rudi
Post22-09-2004, 8:44    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
While this doesn't affect me personally, do you have an order number and the price?
Best regards, Rudi.
Translated on 12-08-2026, 2:05.
CheBu
Post22-09-2004, 8:52    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Unfortunately, there is no order number. It was free of charge! That's why I'm so happy.
That's what I call customer service.
I think these discs are comparable to the current suspension systems from KW.
HA was attached to circumvent these issues.
Stefan.
Translated on 12-08-2026, 2:06.
Rudi
Post22-09-2004, 10:24    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Hmm...
If the creaking is a problem specific to KW suspension systems, they should also address it.
that they get this under control and help the affected customers.
Apart from that, I still think the company's straightforward response is great, because unfortunately...
It's no longer common to treat customers in that way (Germany's service desert icon_evil.gif).
Does this problem also occur with the standard suspension?
Best regards, Rudi.
Translated on 12-08-2026, 2:07.
CheBu
Post22-09-2004, 10:53    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Unfortunately, I can't recall whether a rubber pad was originally installed under the upper spring plate.
If not, does this problem also occur with coil springs? If so, no squeaking can occur on the friction surface...
It's probably only available on the 4Motion models, as my understanding is that even the rear suspension on the 2WD models uses McPherson struts.
Stefan.
Translated on 12-08-2026, 2:08.
Hati
Post22-09-2004, 11:16    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Hi Stefan.
If you're referring to the rear suspension of a Golf IV/Bora with 2WD, it has separate shocks and springs at the rear.
Translated on 12-08-2026, 2:09.
CheBu
Post23-09-2004, 8:16    Subject: 4-Motion Rear Noise? KW GmbH Fixes It! Quote
Next time, I'll check under the vehicles before I write anything!
You're welcome, Hati.
Stefan.
Translated on 12-08-2026, 2:10.
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Folding table with backrest detaches Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Door Seal Repair: 2000 Model Drip Cover Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear brakes not engaging properly on VW Golf G4 Transmission, Chassis, Body & Interior
No new posts G IV AJM 4 motion rucken Diesel Engine Technology
No new posts Front Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Brake Pedal Noise: Causes and Solutions Transmission, Chassis, Body & Interior
