VW T4 CLIMAtronic: 1999 Model
Rübe
Post09-02-2006, 10:11    Subject: VW T4 CLIMAtronic: 1999 Model Quote
The blower fan in the Climatronic system of my VW bus is not running at its highest speed.
I suspected a faulty resistor, but I can't find one.
Can anyone please help me? Regards, Rübe.
Translated on 30-09-2026, 1:35.
Ross-Tech-Support
Post09-02-2006, 10:43    Subject: VW T4 CLIMAtronic: 1999 Model Quote
Error codes read? Are the measured values plausible?
UdoZ
Post09-02-2006, 12:07    Subject: VW T4 CLIMAtronic: Repair & Parts (1999) Quote
If you're referring to one of the interior fans (which one)?
There are no pre-resistors. Each of the three blowers is controlled by blower control units, which are in turn controlled by the Climatronic system.
If the blower is not working correctly, the problem could be due to a mechanical issue (e.g., a clogged filter, the blower possibly being slightly blocked) or an electrical issue (e.g., incorrect sensor readings, a problem with the control unit).
If it's the front blower motor, sometimes hitting the relay with the number 140 can help. If it gets better then, replace it; it's a common problem.
zaydo
Translated on 30-09-2026, 1:37.
Rübe
Post10-02-2006, 14:15    Subject: VW T4 CLIMAtronic: 1999 Model Quote
Code:
Fehlerspeicher ausgelesen? Messwertgruppen plausibel
Good tip, but how does that work?
Translated on 30-09-2026, 1:38.
Rübe
Post10-02-2006, 14:25    Subject: VW T4 CLIMAtronic: 1999 Model Quote
Code:
Wenn Du eines der Innenraumgebläse meinst (welches?):
I didn't know there were 3 blowers. I only know of 2: one for the passenger compartment and one in the front, to the right, behind the pollen filter.
And where is the third one?
No new posts Temperature Difference in Passenger Compartment (A6) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production period up to 09/1999, cigarett... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Anti-Theft Alarm System for VW Golf III 1994 Diesel Engine Technology
No new posts VAG-COM: Reset CLIMAtronic to Default Settings On-Board Diagnostics (OBD)
No new posts Passat CLIMAtronic Reset: 2002 Model On-Board Diagnostics (OBD)
No new posts CLIMAtronic error code 4A4, what does this mean? On-Board Diagnostics (OBD)
