Pierburg MAF Sensor: Now Officially for TDI Engines
Go to page: 1, 2, 3  Next
hame22
Post22-01-2005, 12:03    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Okay, here's the translation:
"Now it's here, the mass airflow sensor from Pierburg for the TDI and the..."
officially.
See:
http://www.msi-motor-service.de/download/luftversorgung/int/pg_luftversorgung_2005.pdf
http://www.msi-motor-service.de/download/luftversorgung/int/lv_z_referenzliste.pdf
There are already some providers listed on eBay.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=9895&item=7949256225&rd=1&ssPageName=WDVW
It's likely that you can also obtain this part through independent automotive parts retailers.
Translated on 24-10-2026, 22:38.
vagtuning
Post22-01-2005, 13:39    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
What is the structural difference between the Bosch and Pierburg mass airflow sensors?
If they claim that the error should not occur again.
Obermeister
Post22-01-2005, 18:34    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Now, the Pierburg mass airflow sensor for the TDI is available.
...back again! There used to be a company called Pierburg. So, my first mass airflow sensor still provides readings of <850mg/h, and that's after 215,000 km. Hopefully, it stays that way.
Master craftsman.
Translated on 24-10-2026, 22:39.
Post22-01-2005, 20:25    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Hi Master Brewer,
You probably mean values > 850, right?
<850 is something every LMM can achieve if you push them icon_smile.gif.
However, this is also dependent on the MSTG regulations. My 1Z engine also has the Pierburg system (which was the only option at the time), and there are no values exceeding 847.9 mg/H.
Translated on 24-10-2026, 22:40.
hame22
Post22-01-2005, 23:18    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
@ vagtuning
If I understood correctly back then, the difference lies...
on the surfaces of the HFM (Hot-Film Mass Flow Meter).
For the Bosch brand, the surface of the HFM is gold-vapor-deposited.
Pierburg has a layer of platinum on it.
This should serve as a protective layer for the membrane, as platinum has a higher...
If a material has high strength, its lifespan should also be longer.
Whether this is still the case, or if other changes have occurred.
I don't know.
http://rb-k.bosch.de/de/start/product_ds_06_luftms_sens.html
Translated on 24-10-2026, 22:41.
Obermeister
Post23-01-2005, 15:35    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
'Every LMM (Large Language Model) can achieve a score of 850 if you feed it the right information.'
...sorry, I misspoke. Actually, my values are greater than 900. I just checked again.
Master craftsman.
Translated on 24-10-2026, 22:42.
ttns4
Post25-01-2005, 12:59    Subject: Pierburg MAF Sensor: Now Official for TDI Engines Quote
'Now it's here, the mass airflow sensor from Pierburg for the TDI and the...'
officially.
See:
'See also my question:'
/viewtopic.php?t=7752&highlight=
Hopefully, this will finally be a lasting solution... Does anyone know the VW costs and the direct solution?
Sure, I'd be happy to.
@hame22 Great information, if that's the case.
'So long'
This phrase is a common way to say goodbye in English. It is similar to the German phrase 'Auf Wiedersehen'.
Here are some other ways to say goodbye in English:
* Goodbye
* Bye
* See you later
* See you soon
* Have a good day
* Take care
I hope this helps!
Thorsten.
Translated on 24-10-2026, 22:44.
hame22
Post25-01-2005, 19:02    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
That's correct.
My friend ordered some car accessories online today.
(Alhambra TDI 110 hp)
Price: €59 + VAT.
The dealer also found the mass airflow sensor in Pierburg's catalog.
Translated on 24-10-2026, 22:46.
herwigw
Post26-01-2005, 11:05    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
That's correct.
Price: €59 + VAT.
I would find it interesting to see comparison logs, for example, of the MWB 008, comparing a working Bosch unit to the Pierburg unit, to see if the Pierburg actually delivers similar values.
I can easily imagine that Pierburg would be interested in being 'slightly' better under the same conditions, because they can assume that this information will quickly spread within the industry, and that, besides the price, it might be the main reason why people wouldn't use the 'original' mass airflow sensor.
Now it's time to wait and hope that someone will take the trouble icon_smile.gif.
herwig
Translated on 24-10-2026, 22:47.
Post26-01-2005, 11:15    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Now, the only question that remains is whether the self-installation into the existing pipe is possible without any problems.
According to my current information, VW only sells the parts as a set, including the pipe, because they are supposedly calibrated together.
That's also why we have that ridiculous 5-sided screw.
Translated on 24-10-2026, 22:49.
Günther
Post26-01-2005, 11:29    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Hello Roger,
The pipe and the installation should be reproducible!
However, I could imagine that transporting it using a pipe would be safer.
Günther.
Translated on 24-10-2026, 22:50.
herwigw
Post26-01-2005, 13:06    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Hello Roger,
Günther
Okay. In the PDF from Pierburg, as shown in Thorsten's post at the top, it states 'Probe without measuring tube.'
I can't quite understand what purpose this requirement serves. Bosch likely offers a version with a pipe, as I've seen at OEAMTC, and that pipe shouldn't be that expensive.
Translated on 24-10-2026, 22:51.
Alois
Post26-01-2005, 13:37    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Why should one replace the pipe and pay for it, especially since it doesn't wear out? What's the obstacle if, instead of using the Phillips head screws that secure the pipe to the air filter housing, you use screws that can be loosened with security bits? Even a regular combination pliers can be used to loosen the screw at the flange, so you don't need to buy any tools just to open those two screws, which you might only need to do every few years. There are no visible modifications to the pipe that would allow for 'tuning' to the mass airflow sensor (MAF), and such modifications would hardly be included in mass production. If desired, after the initial disassembly, you can also replace the security screws with Phillips head screws.
Translated on 24-10-2026, 22:52.
Marzocchi
Post26-01-2005, 18:18    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
"Yes, I also installed a PD (positive displacement) blower from a different manufacturer into my ALH (Audi A4/A6/A8 engine). It works great. Because the blower's intake pipe is slightly different, I also had to loosen those infamous safety screws. You wouldn't believe it, but they come loose easily if you grip them on the edge with a simple, ribbed pliers. Even if you only have a cheap, generic pliers from a discount store like Aldi."
PS: I'm also curious to see what values the new LLMs will produce.
Golf IV - ALH - Erstzulassung 9/99
Translated on 24-10-2026, 22:53.
FrankN
Post14-03-2005, 0:53    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
I think it's important to mention one more thing:
The replacement mass airflow sensor (MAF sensor) from Pierburg requires a modification approval process because only a parts testing certificate is included.
The vehicle registration documents also need to be corrected.
However, this has been postponed until the next time the licensing authority reviews the vehicle documents.
The eBay seller that hame22 linked to also mentions the parts certificate.
I hadn't looked at the link, so I ordered the LMM (lambda sensor) from a local parts supplier.
This is not meant to be an accusation.
I just want to point out the additional costs that arise when you want to comply with the German Road Traffic Regulations (StVZO).
Frank.
Translated on 24-10-2026, 22:55.
Günther
Post14-03-2005, 0:58    Subject: Pierburg MAF Sensor: Now Officially for TDI Engines Quote
Frank
Who will notice that, and who will complain about it?
Best regards, Günther.
Translated on 24-10-2026, 22:57.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Pierburg 1.9 Tdi Tandem Pump Diesel Engine Technology
No new posts LMM (Pierburg) cleaning Diesel Engine Technology
No new posts Pierburg: Troubleshooting & Diagnostics Tips Diesel Engine Technology
No new posts Pierburg Mass Air Flow Sensor Comparison On-Board Diagnostics (OBD)
