Passat 3C TDI Engines: Specs & Problems
Post13-09-2006, 13:37    Subject: Passat 3C TDI Engines: Specs & Problems Quote
Can someone provide information about the TDI engines in the Passat 3C?
I know BKC, BKD, BMM, and BMN, but I no longer remember exactly what they stand for.
We need five of each: 105 with/without, 140 with/without, and 170 with filter.
Okay, here's the translation:
Thank you.
Translated on 26-10-2026, 4:14.
bloesch
Post13-09-2006, 15:35    Subject: Passat 3C TDI Engines: Specs & Problems Quote
hi.
According to my information, the BKD (103 kW), BMM (103 kW), and BMN (125 kW) engines were not used in the Passat.
Here is my information:
mkb - kw
bkc 103
bkp 103
bls 77
bma 100 (*edit*)
bmp 103
bmr 125
buz 120
BWV 88.
bxe 77
Translated on 26-10-2026, 4:16.
Post14-09-2006, 17:47    Subject: Passat 3C TDI Engines: Specs & Problems Quote
Thank you.
which ones have filters and which ones don't?
Greetings.
Martin.
Translated on 26-10-2026, 4:17.
bloesch
Post14-09-2006, 18:41    Subject: Passat 3C TDI Engines: Specs & Problems Quote
Well, unfortunately, my information on that topic is quite limited. I only found information about whether a car has a DPF (Diesel Particulate Filter) or not for the A3 (8P) model.
In the A3, the BMN and BLS engines apparently came with a particulate filter (DPF), but as far as I know, the Passat didn't have that.
[There are more options available for the A3, including those with a filter.]
However, I cannot say for sure whether the BLS system in the Passat also has a filter.
It might also be due to the year of manufacture.
Unfortunately, I can't say anything more about that.
P.S. The engines mentioned above are, as you probably already guessed, not necessarily all available in Germany. (I believe this includes the 120kW, 88kW, and 90kW models).
Furthermore I believe that the 100kW engine (BMA) has a DPF. I accidentally wrote 103kW in the first post...
Translated on 26-10-2026, 4:18.
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts Differences V.A.G. Engines AFN, AHH, AHU Diesel Engine Technology
No new posts Auxiliary Heater for PD Engines Diesel Engine Technology
No new posts Future TDI engines Diesel Engine Technology
No new posts Engine Swap: BMW E2 CAN Engines On-Board Diagnostics (OBD)
