Airbag Adapter: Installation & Compatibility Guide
Holger247
Post08-10-2004, 11:27    Subject: Airbag Adapter: Installation & Compatibility Guide Quote
wenn ich meinen Sitz im GIV ausbauen möchte, sollte ich ja laut Rep-Anleitung einen Airbag-Adapter anschließen, damit der Sitzairbag nicht durch statische Aufladung versehentlich ausgelöst wird. SoKeep up the good work.
Unfortunately, I don't have such an adapter – and knowing my friend, he probably wouldn't lend it out either.
Now I know that many people are simply being cautious by disconnecting the battery and removing the seat without the adapter – there are probably very few problems with this approach.
Can you build an airbag adapter yourself? Do the two wires simply get shorted together? Or is the flow of electricity prevented, for example, by using two diodes connected in series with opposite polarities?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 10-08-2026, 7:24.
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lederlenkrad nachrüsten trotz Airbag Troubleshooting & Guides
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diag. Adapter über USB-Adapter:Login nur in Motorsteuerg... On-Board Diagnostics (OBD)
No new posts Airbag malfunction Diesel Engine Technology
No new posts Airbag Fehler On-Board Diagnostics (OBD)
No new posts Airbag actuator diagnosis On-Board Diagnostics (OBD)
