Draft Horse Shakes/Bucks
tim27
Post14-07-2002, 9:10    Subject: Draft Horse Shakes/Bucks Quote
Hi everyone,
Last night, I noticed that my TDI 1Z engine was experiencing some slight jerking in 5th gear when 'coasting,' around 1100 RPM. The jerking disappeared once the RPM reached 1250. I suspect it might be related to the fuel quantity adjuster, because I had adjusted it slightly before.
Or am I wrong?
Translated on 25-10-2026, 21:59.
Post14-07-2002, 9:33    Subject: Engine Misfire: Troubleshooting & Repair Quote
Hi.
If you've ever adjusted the control lever towards the fuel injection lines, it's very likely due to that.
There is an entry in the error database about this (DIY solution for stuttering).
The topic is also briefly addressed in the new article about the rule-making authority.
Translated on 25-10-2026, 22:00.
This topic is locked, you cannot edit or reply. 1Z TDI Shakes at 60-85 km/h Diesel Engine Technology
No new posts ARL Improves Cold Start Performance On-Board Diagnostics (OBD)
No new posts A3 8P 2.0 TDI: Engine Misfire at Idle On-Board Diagnostics (OBD)
No new posts Engine Misfire: Grey Smoke Explained Diesel Engine Technology
