Fan starts at 97.8°C - Is this normal?
Arne
Post12-07-2002, 8:55    Subject: Fan starts at 97.8°C - Is this normal? Quote
Hi everyone,
The fan on my Audi starts at approximately 97.8 degrees Celsius.
Then it cools down quite quickly to 95 degrees. But even so, it still seems a bit late to me.
I would be very happy to hear your thoughts on this.
Arne.
Translated on 15-10-2026, 18:54.
Post12-07-2002, 17:11    Subject: Relays: Types, Applications, and Uses Quote
Hi.
According to the "How-to" manual for the G3, the switching levels for the thermostat are:
Stage 1: Heat to 92-97°C, then reduce heat to 84-91°C.
Set the temperature to level 2 at 99-105°C, and reduce it to 91-98°C for the final stage.
The switch is located (at least on the G3 model) at about half the height of the radiator, which, in my opinion, is already a bit cooler than at the engine outlet where the temperature sensor is located.
--> A sensor that provides slightly higher readings, and a switch that activates a bit later (all within the normal tolerances), could, in my opinion, already explain your observation.
Did you determine the "comma temperature" using VAG-COM?
Translated on 15-10-2026, 18:55.
DeathAngel69
Post13-07-2002, 11:59    Subject: Think is right! Quote
According to my VAG-COM readings, the fan doesn't turn on until the temperature reaches 97-98 degrees Celsius, and that's on the first setting. I can barely get it to run on the second setting when the car is stationary. It only works if I turn on the air conditioning.
Translated on 15-10-2026, 18:57.
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injection Timing: 17 Degrees BT - Is It Safe? Diesel Engine Technology
No new posts The outside temperature sensor is showing a reading that ... Transmission, Chassis, Body & Interior
No new posts JMA: Better Performance at -13°C? Diesel Engine Technology
No new posts Audi A4: Starting Problems Below 5°C? Transmission, Chassis, Body & Interior
