Are the AFN and AHU cable harnesses identical?
Henrik
Post10-10-2004, 20:33    Subject: Are the AFN and AHU cable harnesses identical? Quote
How to...
I have an AHU, and I'm considering installing an AFN.
What parts do I need?
Does the gearbox function properly? Does the cable harness fit? (Of course, the control unit from the AFN can be connected)
LLK equal?
Thank you very much!
No new posts Injection pump, identical? Diesel Engine Technology
No new posts Which PDEs are identical? Diesel Engine Technology
No new posts Oil Pan: Same for 85kW/96kW Engines? Diesel Engine Technology
No new posts Are Caddy TDIs with 105 hp and 75 hp identical (except fo... Diesel Engine Technology
