Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
28-11-2002, 1:20 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
While experimenting with VAG-COM and adaptation channel 1, I noticed that increasing the value results in characteristics typical of a very minor "Pup" connector pin 2/3 tuning.
- The idle speed is adjusted to decrease when you release the accelerator.
- Slight jerking at very low throttle levels, "operating state = extreme partial load range."
I therefore conclude that increasing the value of Channel 1 shifts the evaluation of the inductances of the control signal generator in such a way that the engine control unit (ECU) perceives that less fuel is being injected than is actually being injected, analogous to the "10-cent tuning" method.
Several months ago, Michael wrote a post on the error database about adaptation channels, along with explanations.
"Quote from Michael"
Select the engine control unit.
Please log in to channels 1, 3, 4, and 5 using the username "12233".
Select adaptation.
Select the corresponding channel and change the value (which can only be changed within certain limits).
Example: Channel 1: Since this information indicates to the engine control unit (ECU) how long the valve was open, an increase in the value results in a reduction of the fuel injection amount.
Example: Channel 2: An increase in value results in a higher idle speed.
Channel 1: Injection amount.
Channel 2: Idle speed.
Channel 3: Air mass.
Channel 4: Injection timing.
Channel 5: Starting amount.
"End quote Michael."
Michael's statement is completely the opposite of my observations.
What is correct then?
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Translated on 25-07-2026, 17:04.
Profile PM Garage |
28-11-2002, 16:16 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Hi Georg,
I suspect that there might also be a small adjustment capability for tolerances during pump calibration behind "Kanel 1".
It also fits with the observation that the displayed fuel injection amount changes, even though the idle speed remains constant.
So, it appears that in the idle range, only the amount of fuel that the engine computer believes needs to be injected is being changed. Gruß Ulf
Translated on 25-07-2026, 17:08.
Profile PM Garage |
29-11-2002, 11:57 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Hello Ulf,
Thank you for your response. That probably clarifies what this adaptation channel apparently does.
What still interests me is the direction things are taking. Michael's contribution and my experiences seem to be moving in opposite directions.
Profile PM Garage |
29-11-2002, 16:42 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Georg_G wrote: |
What still interests me is in which direction things are developing. Michael's contribution and my experiences contradict each other. |
Hi Georg,
If you believe the theory, does the injection amount increase when the jerk tendency increases (and vice versa)?
I guess there must have been some misunderstanding in Michael's post. Gruß Ulf
Translated on 25-07-2026, 17:09.
Profile PM Garage |
robo pd Guest
06-12-2002, 20:03 Subject: AJM: Adaptation Pathways and Channels |
I tried using VAG COM to change the fuel injection quantity and injection timing. The value is displayed in the test field, but it's not accepted for saving. I was able to successfully change the mass airflow sensor target value and idle speed. Does anyone have an explanation for this?
Best regards, Roman.
Translated on 25-07-2026, 17:11.
frebert Blaumann
Joined: 07/26/2004 Posts: 71 Karma: +3 / -0 Location: Chiemgau
06-10-2004, 18:14 Subject: Summary: How to Write a Great Summary? |
Hello Forum users,
Okay, so I've been looking at some posts about the topic of adaptation in relation to...
I have read the soot development, fuel injection amount, and idle speed data, and I consistently find contradictions. Could someone summarize this for me?
For example: An increase in the value in channel 1 results in...
... on channel 3 ... on channel 4, etc. ... If channel X is changed, it makes sense to also modify channel Y so that...
And one more thing, what does channel 00 with the "factory settings" do, or rather, what does it reset?
Thank you  .
Greetings.
Frebert. 1,9 l AFN mit Schick Wasser LLK im T3
Translated on 25-07-2026, 17:12.
Gremlin Guest
07-10-2004, 6:52 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Just do the following:
Turn on the air conditioning or use a high-power appliance.
Maintain the engine speed at 2000 RPM using the accelerator pedal.
'Mess around in first gear without touching the accelerator pedal.'
Based on the reaction, you can already see how it works...
CU Gremlin.
Translated on 25-07-2026, 17:14.
frebert Blaumann
07-10-2004, 10:54 Subject: Gremlin: Troubleshooting and Solutions |
Hi Gremlin,
I don't know what to do with your answer; I've already tried a lot of things, but a well-founded explanation would be simpler.
Franz. 1,9 l AFN mit Schick Wasser LLK im T3
Translated on 25-07-2026, 17:15.
ttns4 Guest
07-10-2004, 12:15 Subject: AJM Adaptation Channels: A Guide |
Greetings, Roman.
Hi Roman, as far as I know, the channel cannot be adjusted on PD motors, even though it appears in the menu; please also check the search function.
Thorsten.
Translated on 25-07-2026, 17:16.
Thomas K. Guest
07-10-2004, 12:39 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
For PD engines, it is naturally possible to modify and save the value for channel 1 (fuel injection quantity).
And an increase in the value definitely results in an increased fuel injection amount for PD engines.
Currently, I'm using channel 03 (AGR rate) with a value of 33368 (maximum value for PD), which represents the minimum AGR rate.
Channel 01 is tuned to 32780.
The starting weakness is reduced, and it runs well  .
Translated on 25-07-2026, 17:18.
07-10-2004, 16:07 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Thomas K. wrote: | For PD engines, it is of course possible to modify and save the value for channel 1 (fuel injection quantity).
The starting weakness has been reduced, and it runs well  | .
Do you have any comparisons to the factory settings, for example, in terms of DZR time?
Has the adjustment shifted the relationship between the displayed average and the fuel consumption during overnight charging? Gruß Ulf
Translated on 25-07-2026, 17:19.
Profile PM Garage |
Thomas K. Guest
11-10-2004, 8:21 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Hello Ulf,
I don't really like the DZR  .
'The top speed hasn't changed, and according to the popometer (likely referring to a boost gauge), there isn't a significant improvement in acceleration either. What has improved is the responsiveness; it feels much more immediate. The average fuel consumption display shows about 0.3 liters more per kilometer on my usual route with the same driving style. However, the fuel consumption at each fill-up remains the same, around 7.3 liters per 100 kilometers.'
Since the adaptation, I can now turn while in third gear without losing acceleration like before; it pulls slowly now, but at least it pulls.
Translated on 25-07-2026, 17:21.
herwigw Guest
11-10-2004, 11:23 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
The starting weakness has been reduced, and it runs well  .
Hello Thomas K.,
Unfortunately, I also encountered the problem described above this weekend with Channel 1 (and Channel 4): The control unit seems to only accept the pre-set value of 32768 and no other value.
However, I was able to easily adjust the idle speed and starting amount – both for testing and saving.
Is it possible that you need a different login than '12233'?
My tools: VAG-COM 4040 + hobby adapter (I'll try it again with a 4090 soon).
Herwig.
Translated on 25-07-2026, 17:23.
11-10-2004, 11:37 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
herwigw wrote: |
Is it possible that you need a different login than the one provided, which is 12233? |
I can even adjust channel 1 on my OBD engine with the value 12233... but I can't adjust the fuel injection timing (isn't that channel 4?).
The thing with Thomas' higher consumption reading since the adaptation is really confusing me...  I would have expected a lower reading. Gruß Ulf
Translated on 25-07-2026, 17:26.
Profile PM Garage |
Thomas K. Guest
11-10-2004, 12:33 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Login is working fine.
I always use a VAG 1552 (I don't have it in front of me right now, but I think that's the name – it's a small device with a two-line LCD display).
Here's the procedure again:
- ECU Selection --> 01-Engine
- 11-Login --> Enter 12233
- 10-Adjustment --> Channel 01 Injection Quantity --> Enter value (mine is 32780, the maximum is 32782) and save.
- 10-Adjustment --> Channel 03 EGR --> Enter value (maximum 33368 for AJM, 33768 for VP-Diesel) and save.
That's all.
The thing about the increased consumption reading also surprised me, but maybe the MSG is processing the higher value to calculate the consumption?
I guess I'll have to buy a VAG-Com after all, because with this small VAG tester, I can only read the current live data, but not create any logs.
Translated on 25-07-2026, 17:28.
herwigw Guest
12-10-2004, 7:32 Subject: Injection Volume Adaptation Channel 1: Troubleshooting |
Hello Ulf,
Unfortunately, I'm really having trouble with this: I can't change the injection amount and timing for channel 1 and channel 4, but I can easily adjust the EGR and initial injection amount for channels 3 and 5.
After trying it again yesterday with VAG-COM 4090, I'm now convinced that the problem isn't related to an incorrect login. It seems that only the original value of 32768 is accepted, and I can correctly save that value as well.
For the adjustable channels, you can test the adjustment range – as described in many threads – by entering a very low value, such as 10000, and clicking 'TEST.' The device will then only accept the lowest possible value (typically 32xxx). The same principle applies when using the highest value.
@Thomas K: Channel 3 is working for me like yours. Unfortunately, channel 1 isn't.
Herwig.
Translated on 25-07-2026, 17:31.
