Car won't start, lights not working
sympatie
2020 Skoda Karoq
Post10-10-2004, 9:29    Subject: Car won't start, lights not working Quote
I have a 1994 Volkswagen Golf III 1.6L gasoline engine that won't start and is currently at the repair shop. The starter switch has already been checked, and all the fuses in the car are fine.
If the warning light on the driver's side turns off when unlocking the car, the immobilizer should actually be deactivated. However, due to the electrical fault, I can't access the control unit to check it.
Does anyone have a tip for me?
"Hello"
Translated on 09-09-2026, 15:43.
vagtuning
Post10-10-2004, 11:59    Subject: Car won't start, lights not working Quote
We once had a 1996 Passat with almost the same symptoms.
No warning lights illuminated, the vehicle wouldn't start, and due to a lack of power to terminal 15, no communication could be established with the control unit. Additionally, the alarm system indicator was flashing erratically and triggering alarms intermittently, even though it was supposedly deactivated. The vehicle could be unlocked, but the alarm indicator continued to flash in some cases.
After a long search, it turned out to be the door handle on the passenger side.
Simply disconnect the connector on the passenger door > A-pillar, and everything started working again (ignition, diagnostics, engine start) - then the door handle was replaced.
Translated on 09-09-2026, 15:44.
Goldhuhn
Post10-10-2004, 22:37    Subject: Car won't start, lights not working Quote
@vagtuning
What exactly is the purpose of the door handle on the passenger side? Does it trigger the alarm system if the handle is activated while the door is closed? And why does the car fail to start when the handle malfunctions?
Seit 221tkm Feb.03 Audi A6 Avant C4, 2.5 TDI, 103KW 140PS, Bj.96, Motor AEL, Getriebe DCF Automatik, Standheizung ab Werk Webasto DBW46
Translated on 09-09-2026, 15:45.
vagtuning
Post10-10-2004, 22:58    Subject: Car won't start, lights not working Quote
'There's something strange with the old Passat. When you briefly interrupt the power supply, the central locking system goes crazy. The DWA (alarm system) doesn't indicate that it should turn off, and then the WFS (window lifter system) doesn't allow it to turn off either, because as long as the DWA is active, the WFS doesn't receive power on terminal 15.'
Translated on 09-09-2026, 15:46.
David
Post14-10-2004, 1:02    Subject: Car won't start, lights not working Quote
I recently had the same problem. In my case, it was the alarm system/immobilizer.
Control unit is not diagnosable.
Installation location: somewhere behind the distribution box insert.
Sometimes, just a few well-aimed hits on the black box are enough.
David
Translated on 09-09-2026, 15:47.
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fan Not Working? Fix It Now! On-Board Diagnostics (OBD)
No new posts A3 Transmission Problems: 3rd, 4th, 5th Gear Not Working? Diesel Engine Technology
No new posts Stuck Glow Plugs - Audi AEL: How to Fix Diesel Engine Technology
No new posts ABS Light On: Window & Turn Signal Problems Diesel Engine Technology
