CBSnake wrote: |
So, regarding my 1999 Ibiza GT (1.9 110 hp), I'm currently experiencing the following problems: strong jerking during partial load operation, which disappears when the pedal is fully depressed; a top speed loss of approximately 10-15 km/h; increased fuel consumption by about 1-1.5 liters; and the preheating indicator sometimes flashes after starting. Then, after turning off the ignition and restarting, it's normal again.
What could it be? I don't want them to replace unnecessary parts in the workshop |
Hi.
Based on my own recent experiences with a (deliberately) adjusted fuel injection control unit, the jerking and flickering remind me of a fuel injection quantity control unit that is no longer operating within its tolerance range.
Increased fuel consumption
and loss of power, in my opinion, are more likely to indicate other problems, such as an EGR valve that is no longer closing properly or a clogged air filter.
Given the "vague" symptoms, I would definitely recommend checking the error memory (or having it checked). If it's blinking, there should be something displayed on it.
