Tip: Dampy interior, Passat 3B
Fireball
Post18-10-2004, 14:57    Subject: Tip: Dampy interior, Passat 3B Quote
Possibly for documentation: I've been searching for a long time, and the problem seems to be not necessarily typical for a Passat 3B - but if anyone else has a similar problem in the future...
The interior on the passenger side was not only damp, but completely soaked... After several hours of searching, including removing the carpet, the source of the problem was finally found - and it wasn't the usual 'sunroof,' 'door seals'...
Located on the Schottwand between the engine compartment and the passenger side interior, underneath the bilge, is a rubber fitting through which the air conditioning lines run. It was also securely in place. But it was still leaking, because the retaining ring, which you can only properly access from the inside, had come loose...
Small cause, big effect. For the past week, it has been dry again icon_smile.gif
Marcus
No new posts Dry the interior General Tips
No new posts Exhaust fumes inside the cabin, VW T6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat/Superb: Accessing Engine Bay from Interior Transmission, Chassis, Body & Interior
No new posts Exhaust Fumes in Car: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Plastic Adhesive for Interior Car Parts Transmission, Chassis, Body & Interior
No new posts Golf 4 Engine Bay to Interior Pass-Through Diesel Engine Technology
