Audi A6 AAT engine failed while driving!
Schouster
Post16-10-2004, 12:05    Subject: Audi A6 AAT engine failed while driving! Quote
Hello everyone,
The following is a description of the situation:
My A6, 2.5 TDI with AAT engine stalled while I was driving. The diesel fuel, timing belt, and shut-off solenoid are all in good condition. The error reading using V.A.G.1551 did not reveal any errors.
What could be the reason for this?
Best regards, Schouster.
Post16-10-2004, 12:10    Subject: Audi A6 AAT engine failed while driving! Quote
Have you already looked for 'Relais 109'?
Schouster
Post16-10-2004, 13:09    Subject: Audi A6 AAT engine failed while driving! Quote
Unfortunately, no Relias 109 was found.
Relay:
Located at the top of water tanks No. 366, 214, 217, 267, and 239.
in compartment numbers 213, 204, 229, and 202.
brezelmann01
Post16-10-2004, 16:11    Subject: Audi A6 AAT engine failed while driving! Quote
I think Rainer was just trying to give you a search term, "Relais 109," that would almost perfectly match your error symptoms. And somehow, your EDC is also being powered, probably through a relay. Whether it's called 109 or 0815 doesn't really matter... I think Rainer's guess sounds quite logical, though.
Do you have any wiring diagrams for your car that I could take a look at?
"Dirk"
Schouster
Post16-10-2004, 17:52    Subject: Audi A6 AAT engine failed while driving! Quote
Unfortunately, I don't have a schematic diagram.
Could someone perhaps check what this relay is called in the AAT / 97 system? Certainly, please provide the text you would like me to translate from German to English. I will provide only the translation.
If this relay is defective, is it still possible to read the error memory? Is the shut-off valve also de-energized in this case? Because it works both mechanically and electrically.
Forto
Post17-10-2004, 11:51    Subject: Audi A6 AAT engine failed while driving! Quote
The relay is located on the auxiliary relay bracket on the right-hand side of the A-pillar.
If this relay is defective, a diagnosis would no longer be possible.
The warning light will also be without power, as will the fuel injection start timing valve, the EGR valve, the turbocharger boost control valve, the fuel quantity control, the clutch pedal switch, and the brake light switch.
Back to top Profile PM Email
Schouster
Post22-10-2004, 7:14    Subject: Audi A6 AAT engine failed while driving! Quote
For your information.
The timing belt has skipped a tooth!
3 valves damaged.
The repair was performed free of charge by the workshop because you had the timing belts replaced only 3000 kilometers ago. The reason for the skipping is unknown to me.
Karma: +437 / -0   Thank you, like it!
Post22-10-2004, 11:55    Subject: Audi A6 AAT engine failed while driving! Quote
Okay, well, I wish you good luck that it doesn't end up being an oil-guzzler later on, because the piston rings might get stuck (due to the valve and piston colliding).
Furthermore, you should definitely investigate the root cause of the problem, otherwise you'll likely encounter the same issue again in a short amount of time, and potentially with even worse consequences. Were all the idler pulleys replaced the first time, or were corners cut?
What type of workshop performed the change?
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KFZ ging während der Fahrt aus Diesel Engine Technology
No new posts T4 engine cut out while driving, and... Diesel Engine Technology
No new posts 2.0 TDI engine cut out while driving and hasn't started s... Diesel Engine Technology
No new posts Passat V6 2.5 stopped while driving - does not start On-Board Diagnostics (OBD)
