Install Outside Temperature Gauge (A6 C4 '97)
inside
Post24-09-2004, 12:35    Subject: Install Outside Temperature Gauge (A6 C4 '97) Quote
hello boys,
Since it's slowly getting colder again, I was thinking about possibly installing an external temperature display.
I have to say that, unfortunately, there's nothing installed behind my combination instrument for that display yet.
If I understand correctly, both the display itself and the temperature sensor would need to be retrofitted.
What do I need for this, and how much effort is involved?
You can occasionally find the display and sensor on eBay.
Thank you for the tips and the help.
Translated on 27-10-2026, 16:46.
olli
Karma: +46 / -0   Thank you, like it!
Post24-09-2004, 20:48    Subject: Install Outside Temperature Gauge (A6 C4 '97) Quote
"I once had to remove the instrument cluster from my A6 because the outside temperature display wasn't working, and as far as I remember, the connections were directly attached to the cluster."
The sensor is located at the front, underneath the bumper; the cable should already be routed there.
Check it out under.
http://www.audiquattro.de/infos/ata/index.htm
Here's a description of the lighting repair; you might be able to understand something from the photos.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 27-10-2026, 16:47.
inside
Post21-10-2004, 16:35    Subject: Bumper location: Where exactly? Quote
Could you or someone else help me with this? If the cable is already installed, does it just hang loose? Please describe it as accurately as possible.
Thank you for your help.
Translated on 27-10-2026, 16:48.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Outside temperature display malfunctioned On-Board Diagnostics (OBD)
No new posts TDI B4: Upgrade GRA (1992) Diesel Engine Technology
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
No new posts VW: Retrofitting LDA (Local Differential Analyzer) Diesel Engine Technology
