Intake Manifold Pressure Problem Solved!:)
Post23-07-2002, 8:17    Subject: Intake Manifold Pressure Problem Solved!:) Quote
Rust was the problem!
The rod connecting the vacuum sensor for the turbocharger pressure regulation was heavily rusted! With a lot of rust remover, a long lever, and a whole lot of force, my friend managed to get the rod working again.
I guess it's because I don't drive much on the highway, only constantly in the city, and apparently the strut doesn't come into use there. Whatever. Now there are no more speed limiters, and you can reach your 160 km/h quickly again on the highway. icon_biggrin.gif
Thank you very much for the help here in the forum.
Translated on 25-07-2026, 19:56.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI AHU; 00575 - Intake manifold pressure regulation diff... On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Differential Regulation Diesel Engine Technology
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Regulation Difference Upload
