OPEL Corsa C: AGR Problems & Solutions
AchimTZR
Post26-10-2004, 18:57    Subject: OPEL Corsa C: AGR Problems & Solutions Quote
Hello forum,
My friend drives a Corsa C 1.7 DTI, manufactured in 2002. Bad enough, but to make matters worse, he recently "destroyed" his AGR icon_lol.gif, and now he doesn't like his car as much as he used to! Of course, he's not happy with the positive side effects of such a "defect," but he has a problem: Between 80 and 90 km/h (approximately 50-55 mph), or between 2000 and 2500 RPM, and only in 5th gear, the engine check light comes on, and the engine goes into limp mode. After briefly turning the car off and restarting it, everything is okay again. This problem apparently only occurs in 5th gear and only within the specified RPM range. It seems that something is monitoring the gear or the speed and triggering the limp mode. I (he) am at a loss here, and we hope you can help us!
Sure, no problem.
Achim
Translated on 16-09-2026, 1:31.
Post27-10-2004, 6:37    Subject: OPEL Corsa C: AGR Problems & Solutions Quote
I'm not entirely sure where the 1.7 DTI engine fits in, but the OBD2 diesel systems monitor the air mass more strictly than the older ones.
Therefore, it is normal for the engine control unit to complain about completely incorrect air mass readings.
So, the AGR needs to be repaired again icon_wink.gif.
Translated on 16-09-2026, 1:32.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAGCOM for Opel Corsa B: Diagnostics & Repair On-Board Diagnostics (OBD)
No new posts Opel Corsa: Blinking Fast - What to Do? Transmission, Chassis, Body & Interior
No new posts Opel Corsa C Start Problems: 1.3 CDTI Fix Diesel Engine Technology
No new posts Corsa B 1.0: Rear drum brakes, bearings, and shoes Diesel Engine Technology
